HELP!! Fuel Pressure Problems #1051819
08/13/11 12:46 AM
08/13/11 12:46 AM
Uniontown, PA
moparmurray Offline OP
Uniontown, PA
Have a 76 Ply Arrow with a stock fuel tank with a sump in it,set the pressure at 7.5 lbs,take the car to the track warming it up and the fuel pressure spikes to 12-15 lbs.Have changed two regulators,& two pumps,still does the same thing.There is no vent on this tank,is this my problem? Thanks,Ron
Re: HELP!! Fuel Pressure Problems [Re: moparmurray] #1051820
08/13/11 12:50 AM
08/13/11 12:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Cant say for sure if thats your problem but you HAVE
to have a vent... as the fuel is pulled out you have
to replace it with air or you go into a vac... not good
Re: HELP!! Fuel Pressure Problems [Re: MR_P_BODY] #1051821
08/13/11 10:32 AM
08/13/11 10:32 AM
Uniontown, PA
Uniontown, PA
Thanks Mr P I knew I could get help from the Moparts Buds.Thank's again Ron
