Alteranator or amp gauge #1051673
08/12/11 07:14 PM
08/12/11 07:14 PM
Allentown Pa.
72dem0n Offline OP
72dem0n  Offline OP
Allentown Pa.
The other day while driving my demon the amp gauge went up to 40 amps drove about 1/2 mile then smelt like a wire burning and amp gauge went to 0. Checked alternator it passed the test at advanced auto. Changed regulator and it started charging again it lasted about 1 minute then stoped charging any ideas what it could be. Thanks Mike
Re: Alteranator or amp gauge [Re: 72dem0n] #1051674
08/12/11 07:19 PM
08/12/11 07:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Disconnect the battery and check the amp gauge terminals for clean and tight.
Re: Alteranator or amp gauge [Re: 72dem0n] #1051675
08/12/11 07:19 PM
08/12/11 07:19 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
What is it for a car? I would check the connections on the ammeter or bulkhead connector.
Re: Alteranator or amp gauge [Re: JonC] #1051676
08/12/11 07:30 PM
08/12/11 07:30 PM
IN
ahy Offline
ahy  Offline
IN
Re: Alteranator or amp gauge [Re: ahy] #1051677
08/13/11 07:35 AM
08/13/11 07:35 AM
Allentown Pa.
72dem0n Offline OP
72dem0n  Offline OP
Allentown Pa.
Thanks I will try that
Re: Alteranator or amp gauge [Re: 72dem0n] #1051678
08/16/11 02:03 AM
08/16/11 02:03 AM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
bypass that ammeter and use a voltmeter.
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
Re: Alteranator or amp gauge [Re: 72dem0n] #1051679
08/16/11 02:45 AM
08/16/11 02:45 AM
find/fix the dead short that made it full field. Start w tracing/examining the blue/green wire field circuits from end to end esp the green one. EDIT find (& post) what wire burnt
