Chute air launcher??? #1051366
08/11/11 09:15 PM
08/11/11 09:15 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Anybody running one? Are they that much better then the standard?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Chute air launcher??? [Re: 65 Hemi] #1051367
08/11/11 10:44 PM
08/11/11 10:44 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I have Stroud spring launchers they will deploy 99.99999999999 percent of the time . Air launchers work great but you cant beat the dependability of a spring. Anything that holds pressure has the potential to leak and cause failure ( that failure would be that the chutes do no deploy and you drive off into the sunset or something not as pretty )
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Chute air launcher??? [Re: go green] #1051368
08/11/11 11:02 PM
08/11/11 11:02 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
I have a freind who uses one and he said it was much faster than one with a pilot chute. He runs all year on one small co2 bottle and it has always worked fine. One thing to remember is if by some chance someone hangs their pants on the cable and your chute pops out in the lanes you better have the tools to reset a spring launcher with you, with a air launcher its just a flip of a switch and no tools.
Outlaw 10.5 526ci, F3R procharged tfx hemi, Big Stuff 3 PTP RACING
Re: Chute air launcher??? [Re: 526ciduster] #1051369
08/12/11 03:25 AM
08/12/11 03:25 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
Use a spring. Not somewhere you want a failure or a leak, etc. A guy I know had one fail after working perfectly in the pits when he tested it, dropped the 'chutes under the wheelie bars and stuffed the car into the wall and rolled it.
Re: Chute air launcher??? [Re: Kevins493] #1051370
08/12/11 09:18 AM
08/12/11 09:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know of OR use any special tools to load my
chute with(cable operated spring launcher)... the air
launchers are nice but I have seen them fail... never
seen a cable operated fail(once the cable length was
set correctly
Re: Chute air launcher??? [Re: Kevins493] #1051371
08/12/11 09:33 AM
08/12/11 09:33 AM
Out West
408strokerdart Offline
Out West
I thought about this also. I will likely go to a spring launcher when I upgrade. They are much faster to deploy and I feel a requirement on fast cars on some of these 1/8th mile tracks here in North Texas. Just not alot of shutdown area.
