hydraulic roller with stock timing cover?
#1051066
08/11/11 11:38 AM
08/11/11 11:38 AM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
Is there any way I can use a stock timing cover and run a hydraulic roller on my 383? I want to use roller lifters but I also want the stock look. Any mods for successful use of a cam button?
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
Re: hydraulic roller with stock timing cover?
[Re: Fishmarket]
#1051067
08/11/11 11:48 AM
08/11/11 11:48 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I didnt use the stock cover when I put a solid roller in my BB, because the endplay on the cam button was speced at .0005-.001 and I didn't see how a flexing sheet metal cover could maintain this precision. I'm using 440 sources alum cover.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Fishmarket]
#1051068
08/11/11 11:56 AM
08/11/11 11:56 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Weld a plate or a thick washer to the timing cover, and then grind the plate or washer to the proper thickness so that it butts up against the back of the water pump.
A little time consuming but has worked great for me, and is dirt cheap.
Rich H.
Esse Quam Videri
[Re: HemiRick]
#1051070
08/11/11 07:43 PM
08/11/11 07:43 PM
Posts: 8,874 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
You might want to recheck those specs !!! .005 - .010 is more like it.
