Car Craft Sm Blk Mopar eng build - 620HP #1051057
08/11/11 11:21 AM
08/11/11 11:21 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Any thoughts from you professional engine builders on this build?? Inquiring minds want to know??
Fastest 300
Re: Car Craft Sm Blk Mopar eng build - 620HP [Re: Crizila] #1051058
08/11/11 11:55 AM
08/11/11 11:55 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Went searching for the article; no luck but did find this
http://www.forabodiesonly.com/mopar/showthread.php?p=1414567
Does OU812 (Brian) still hang around here? Ask him!
Re: Car Craft Sm Blk Mopar eng build - 620HP [Re: RodStRace] #1051059
08/11/11 12:13 PM
08/11/11 12:13 PM
SoCal
Brian Hafliger Offline
SoCal
Always hanging out!
Brian Hafliger
Re: Car Craft Sm Blk Mopar eng build - 620HP [Re: Brian Hafliger] #1051060
08/11/11 12:35 PM
08/11/11 12:35 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Always hanging out!
Slacker!
Good Job Brian.
Re: Car Craft Sm Blk Mopar eng build - 620HP [Re: RodStRace] #1051061
08/11/11 01:32 PM
08/11/11 01:32 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
October issue of Car Craft - but what you posted is it. Awesome #'s when you consider how many off the shelf parts were used -inparticular on the bottom end. Going to use the pan gasket trick on an existing 360 build. If I had any concerns at all on the bottom end it would be along the lines of longivity - no studs, girdle, hard block, etc. Also interesting approach to get to that magic 300# with stock configuration heads - with no filler. Sez something for hand porting - all 2 days worth. Of course the only thing that is stock on the heads is the the configuration. No mention of any oiling / cooling mods. Guess there weren't any? Big $ in the valve train to handle that cam, but looks to be pretty bullet proof. IMO, overall pretty damned impressive for a stock blocked, 10.9:1 CR motor.
Fastest 300
Re: Car Craft Sm Blk Mopar eng build - 620HP [Re: Crizila] #1051062
08/11/11 02:21 PM
08/11/11 02:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
day late and a dollar short...or should I say $12,000 short
Coming soon!!!!
Re: Car Craft Sm Blk Mopar eng build - 620HP [Re: Crizila] #1051063
08/11/11 02:50 PM
08/11/11 02:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does anyone know if its on the stands yet
Re: Car Craft Sm Blk Mopar eng build - 620HP [Re: MR_P_BODY] #1051064
08/11/11 03:14 PM
08/11/11 03:14 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Impressive work as always, Brian!!
Pretty close in design concept to my own 414, my SDSS E-heads don't flow that well up top (puny 2.02's) but the cam is pretty close (266/269) but a tighter (107) spread. I figure mine for a solid 550 horse...maybe a little more.
WIZE
In Car:
Re: Car Craft Sm Blk Mopar eng build - 620HP [Re: Streetwize] #1051065
08/11/11 08:23 PM
08/11/11 08:23 PM
SoCal
SoCal
In the imortal words of Elvis "thank you...thank you very much"!
Brian Hafliger
