Re: 426 Hemi and 727 automatic transmission questions.....
[Re: Finoke]
#1050730
08/10/11 07:29 PM
08/10/11 07:29 PM
Posts: 4,285 Ohio
64dodge572
Ohio
The tailhousing from the small block 727 will work on the big block case. You may need to modify the linkage rod from the rear carb to the cable bracket pivot. Everything else from there down would be fine.
Wayne
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#1050731
08/11/11 07:29 AM
08/11/11 07:29 AM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
Wayne
Thanks Wayne, I like it
