Rocker shaft oiling holes which direction?/Oil drive?? #1050653
08/10/11 05:08 PM
08/10/11 05:08 PM
Hr up from KCK
451 D*O*D*G*E Offline OP
Hr up from KCK
B engine,I have had it apart to long and also forgot to mark which side is which.Do the oil holes which you know are off center of the bolt holes favor the valve side or lifter???.........also does the oil drive need to point at something like i use to do on the LA engines??Thanks gonna mow then check back
1970 Challenger R/T clone 2010 Dodge Journey R/T black,awd,
Re: Rocker shaft oiling holes which direction?/Oil drive?? [Re: 451 D*O*D*G*E] #1050654
08/10/11 05:23 PM
08/10/11 05:23 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Oil holes down!!!!!Drive gear can go anyway but you want to set the direction the rotor faces..
Re: Rocker shaft oiling holes which direction?/Oil drive?? [Re: dynamite] #1050655
08/10/11 05:27 PM
08/10/11 05:27 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
yeah, holes are down and face out towards the exhaust.
Re: Rocker shaft oiling holes which direction?/Oil drive?? [Re: dynamite] #1050656
08/10/11 06:57 PM
08/10/11 06:57 PM
Hr up from KCK
Hr up from KCK
I knew they didnt face to the sky
OK thanks you guys very much
Re: Rocker shaft oiling holes which direction?/Oil drive?? [Re: 451 D*O*D*G*E] #1050657
08/10/11 07:25 PM
08/10/11 07:25 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yeah, man oil holes down and towards valves, and intermed shaft slot should be parrallel to cam/crankshaft centerline which will leave the rotor pointing pretty much at fuel pump when at top dead center firing cyl #1. Note: some aftermarket distribs have different indexing, so watch for variences with them.
Re: Rocker shaft oiling holes which direction?/Oil drive?? [Re: ireland383] #1050658
08/10/11 08:19 PM
08/10/11 08:19 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
yeah, holes are down and face out towards the exhaust. [/quote
Yup, Down and Out. EZ to remember that way.
Re: Rocker shaft oiling holes which direction?/Oil drive?? [Re: pishta] #1050659
08/11/11 12:20 AM
08/11/11 12:20 AM
Hr up from KCK
Hr up from KCK
