What hood scoop for 67 Charger
#1050505
08/10/11 03:03 PM
08/10/11 03:03 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I need a bigger scoop then the 4" I have but just cant find anything that would look ok. I like to street drive it a little.
67' charger 499 RB
10.57 at 127
Re: What hood scoop for 67 Charger
[Re: Mr.Yuck]
#1050507
08/10/11 03:26 PM
08/10/11 03:26 PM
dragram440
bigfork mn
I have seen some 4" cowls for it but I dont think that is big enough. Mine now is between 3" and 4" as it tapers to the back and my carb vents are 1/2" from the bottom of my scoop. I have seen a few people with 5" 6 pack scoops that I really like but I can find any.
67' charger 499 RB
10.57 at 127
[Re: dOc !]
#1050512
08/10/11 05:12 PM
08/10/11 05:12 PM
dragram440
bigfork mn
Thanks for the link! some sweet ones on there. Would the 5" hemi scoop or the 5" six pack scoop look better on my car?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1050516
08/10/11 05:34 PM
08/10/11 05:34 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
6-pack hoods look good on 68-69 b-bodys except chargers. My 1st choice for your car would be the 5" WO scoop 2nd would be a 5" Hemi (dart) scoop
[Re: Sledge_57]
#1050519
08/11/11 02:03 AM
08/11/11 02:03 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Here's the one Mr.Yuck was referring to on my '67. '68 Hemi Dart from VFN
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#1050520
08/11/11 02:08 AM
08/11/11 02:08 AM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
Aside from crying every time I see your car.... do you like the quality of the VFN scoop? Well made? Bolts down in a sturdy way?
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#1050521
08/11/11 02:17 AM
08/11/11 02:17 AM
67Charger
Erda, UT
ummm... worth what I paid for it. I had to grind the bottom to match the hood contours, but that left the bolt tabs below the bottom of the edges. I re-bent them with pliers and all was well. Second, I ran the scoop ONCE at the strip before realizing I required those 3 hold downs in the front. I glassed in some special perforated washer/nuts that I got from McMaster-Carr for about $2 each and added some all thread and stainless tubing. Now it's solid as a rock at nearly 130 mph. I couldn't justify the expense of a new glass hood when this was so easy, not to mention a glass hood would also need work to fit/hinge/bolt, etc.
Yes, I'd do it again.
[Re: dragram440]
#1050523
08/11/11 01:24 PM
08/11/11 01:24 PM
67Charger
Erda, UT
I'll measure it when I get home. It is definitely the same style as yours, but as far as height goes, I think it is about 2 1/2 at the rear and 5" to the peak in the front.
