Oil foam? #1050319
08/10/11 11:49 AM
08/10/11 11:49 AM
Outside
thedriver Offline OP
Outside
Why does oil foam up? I have a Chevrolet v6 that runs off natural gas powering a pumpjack, noticed this morning the sight glass for oil is full of foam??
1973 challenger
Dana. 4 speed. Low deck.
Re: Oil foam? [Re: thedriver] #1050320
08/10/11 11:59 AM
08/10/11 11:59 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Water in your oil. Could be a number of ways it got there; cracked block/heads, bad head gasket(s), or simply condensation.
Re: Oil foam? [Re: Fat_Mike] #1050321
08/10/11 12:01 PM
08/10/11 12:01 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
dont rule out condensation...if the engine is not run very often, condensation can be an issue.
I had that issue with my 4.3 V6 when I was only making very short drives with it irregularly...
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Oil foam? [Re: thedriver] #1050322
08/10/11 01:20 PM
08/10/11 01:20 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
what kind of oil are you useing?
Re: Oil foam? [Re: MAVERICKSHEMI] #1050323
08/10/11 02:14 PM
08/10/11 02:14 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Don't know where you are but this year has had excessively high humidy and leads to a lot of moisture accumulations in many places including our engines if not run long.
Re: Oil foam? [Re: thedriver] #1050324
08/10/11 02:34 PM
08/10/11 02:34 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
