Best Single Plane Intake - 4500 Flange
#1050303
08/10/11 10:31 AM
08/10/11 10:31 AM
Posts: 119 Orangeville, Ontario, Canada
Red Express
Hello,
I'm looking into switcthing from my tunnel ram setup to a single carb. Currently running two 750's on a weiland tunnel ram... Using Indy 440-SR heads, which I beleive are the same config as the stock heads.
Which intake would you recommend I look for, looking for the same or better performance as the ram.
What have you had success with.
Darcy & Allan MacCoubrey
Worlds Fastest Lil Red Express Truck
10.48 @ 128 mph
[url] www.raceosca.com [/url].
Re: Best Single Plane Intake - 4500 Flange
[Re: AndyF]
#1050306
08/10/11 12:11 PM
08/10/11 12:11 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i was reading a post on here in the tech archives recently and it was a dyno comparison between a bunch of intakes and the TEAM G 4500 intake was stellar but i cant remember what the intakes were that it was compared to
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Red Express]
#1050307
08/10/11 12:44 PM
08/10/11 12:44 PM
Posts: 43,254 Bend,OR USA
Cab_Burge
Hello,
Which block are you using, low deck(361-400) or tall deck(413-440)I have several different single 4500 manifolds for both, only need one of each PM if you want about the details and $ amounts
