Aluminum Cleaner? #104989
08/14/08 08:31 PM
08/14/08 08:31 PM
CrazyD Offline OP
CrazyD  Offline OP
Anyone know of a spray on and hose off aluminum cleaner? I ahve some fan clutches I want to clean, and with all the fins, need something that works without rubbing, and washes off.
Re: Aluminum Cleaner? [Re: CrazyD] #104990
08/14/08 08:57 PM
08/14/08 08:57 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
I think wheel cleaner would work.
'71 SSP - SOLD!
Re: Aluminum Cleaner? [Re: Mobarge] #104991
08/14/08 09:00 PM
08/14/08 09:00 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Wheel acid can turn raw aluminum white as a ghost so be carefull what type you try.
I'd just use some simple green or carb cleaner and a cut down paint brush to scrub between the fins.
Re: Aluminum Cleaner? [Re: CrazyD] #104992
08/15/08 09:42 AM
08/15/08 09:42 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I agree wit the problems of using anything acid based. But using something mildly caustic might be you solution. I also would make sure I am not applying to anything highly stressed since you could start a sress/corrosion issue not visible to the eye. Try a strong solution of "simple Green" avaliable at most hardware stores/Home Depot, let it sit for a few minutes, it will brighten it up.
Re: Aluminum Cleaner? [Re: jcc] #104993
08/15/08 10:20 AM
08/15/08 10:20 AM
scratchnfotraction Offline
some coil cleaner for home A/C units will work
spray on wash off I have used it for alum wheels,fan clutchs,alum vc,alum intakes
may want to spot check how it does first though
Re: Aluminum Cleaner? [Re: CrazyD] #104994
08/15/08 12:46 PM
08/15/08 12:46 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Check out some products designed for motorcycles. Most MC shops (Honda, Harley D. etc.) offer various products designed for spraying on and hosing off. I've used several that work surprising well. Don't laugh, Pig Snot is good stuff. Checkout the HD shops, they tend to be particular about the products they offer.
Re: Aluminum Cleaner? [Re: cruzin] #104995
08/15/08 05:13 PM
08/15/08 05:13 PM
CrazyD Offline OP
CrazyD  Offline OP
FYI, coil cleaner did nothing, most of it ran right off. Active ingredient is phosphoric acid - it may work on copper, but had zero effect on an alunimum fan clutch.
Re: Aluminum Cleaner? [Re: CrazyD] #104996
08/15/08 10:09 PM
08/15/08 10:09 PM
ARK , Fixing something
Bee4Me Offline
super gas
Bee4Me  Offline
super gas
Being in the hvac biz,there are 2 types of coil cleaners.
The acid type will only work on fairly clean aluminum and it will brighiten it up.
What you want is a non acid,foaming alkaline type cleaner which contains Sodium Hydroxide aka LYE. These are used for general cleaning of dirt,grime,oily gunk removal.Ask for some Renuz or for SERRIOUS cleaning,Black Max. Use rubber gloves and saftey glass's cause this stuff DON'T play.
Issue will be how much Maginesium is in the Aluminum cause it WILL turn it BLACK if it has a high mag content.
You can try some Mag wheel cleaner as well or even some Easy Off oven cleaner.
I use both when cleaning,etching my aluminum panels. Each will give true aluminum a different color finish. Acid is bright,Alkaline is a touch darker.
If you look at the trans tunnel junction right below the shifter,you'll see the difference between acid,front and alkaline,back and also matches the shifter cover. Yeah it's a Chebell and the owner wanter it that way,but ther IS a difference in how each chem reacts with the aluminum.
Re: Aluminum Cleaner? [Re: Bee4Me] #104997
08/15/08 10:42 PM
08/15/08 10:42 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I've used Eagle 1 mag cleaner for years on uncoated aluminum parts. It will strip ALL the tarnish off so yes, as one of the guys mentioned, it will be very bright. Back when I used it on my old slotted US Mags back in the day, all the rest of the guys wanted my secret.
I’m listening.
Re: Aluminum Cleaner? [Re: Big Bad Bee] #104998
08/16/08 01:05 AM
08/16/08 01:05 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Yup, Eagle 1 etching cleaner works wonders with slots, spray it on, wait about 1 minute and rinse, repeat if needed, but no longer than 1 minute or whatever the bottle says.
