Mopar Muscle article #1049711
08/09/11 12:21 AM
08/09/11 12:21 AM
70duster340 Offline OP
In the October 2011 issue, there is an article about whether or not a ballast resistor is needed. In the article it is stated that a ballast resistor is needed with points-type ignition, but can be removed if there is an electronic ignition in place. What is the consensus from you folks? I would like to run without one, if at all possible.
Re: Mopar Muscle article [Re: 70duster340] #1049712
08/09/11 12:44 AM
08/09/11 12:44 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Just carry an extra in the glovebox, the br steps the voltage down to 6v after start which is needed even after electronic ign conversion.
-Daty
Re: Mopar Muscle article [Re: Daty Rogers] #1049713
08/09/11 12:48 AM
08/09/11 12:48 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
3 of my cars use an MP distributor to signal an MSD unit; no "box" or ballast resistor. Use the later voltage regulator (which you should already have in a '70), and connect the ballast resistor wires with a 10ga. wire.
Re: Mopar Muscle article [Re: topside] #1049714
08/09/11 01:13 AM
08/09/11 01:13 AM
How about the Pertronix Plug and Play distributor?
Re: Mopar Muscle article [Re: 70duster340] #1049715
08/09/11 02:13 AM
08/09/11 02:13 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I just read that article a few hours ago and wondered the same thing the OP asked. I'd be inclined to trust Richard Ehrenberg from Mopar Action magazine before the guys at MM. Steve Dulcich was pretty sharp too. I haven't seen him post here in a while.
I suppose that you can bypass the ballast and find out for yourself.
Re: Mopar Muscle article [Re: Kern Dog] #1049716
08/09/11 03:02 AM
08/09/11 03:02 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
most regular coils need a ballast resistor and even have it printed on it. you would need a full 12v voltage coil to bypass the B/R
Re: Mopar Muscle article [Re: ademon] #1049717
08/10/11 12:30 AM
08/10/11 12:30 AM
Would removing the ballast resistor cause the ECM to burn out?
Re: Mopar Muscle article [Re: 70duster340] #1049718
08/10/11 12:50 AM
08/10/11 12:50 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I neglected to mention that 2 of my cars run the MSD Blaster 2 can-style coil, the 3rd car runs the old Accel big yellow coil. One's been running that way since 1988, the other probably late '70s.
Re: Mopar Muscle article [Re: topside] #1049719
08/10/11 01:19 AM
08/10/11 01:19 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Along with the Blaster II, What ignition box?
1. Mopar chrome box, the ballast resistor should be 0.25 Ohms.
2. MSD box, no ballast resistor.
Just my $0.02...
Re: Mopar Muscle article [Re: 70duster340] #1049720
08/10/11 08:27 AM
08/10/11 08:27 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
so soon?? your cars will run without one. it's there to increase the life of your electronic parts. plain and simple. your choice. sorta like seatbelts for your ECU or coils.
Re: Mopar Muscle article [Re: mikemee1331] #1049721
08/10/11 10:17 AM
08/10/11 10:17 AM
NY usa
540challenger Offline
NY usa
I started a thread about no ballast a few days ago losts of good info in it.
https://board.moparts.org/ubbthreads/show...e=6#Post6761068
Re: Mopar Muscle article [Re: 540challenger] #1049722
08/10/11 11:38 AM
08/10/11 11:38 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Haven't seen the MM article, but did see the MA.
Running a Blaster 2 w/o a ballast works fine. For a long time. For many many miles. In high heat.
I think somebody linked the other recent thread about it. I will say again that this seems to be an engineering theory that was thrown out there. People then ran with it and little actual testing was done. It's unlikely that I happened to have a one off set of parts that happen to work well, despite the dire warnings.
I want my fair share
Re: Mopar Muscle article [Re: 70duster340] #1049723
08/10/11 01:44 PM
08/10/11 01:44 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
According to the directions I have for mine, it clearly states to "by-pass" the Ballest Resistor...
Re: Mopar Muscle article [Re: CR8CRSHR] #1049724
08/11/11 11:01 PM
08/11/11 11:01 PM
Since I don't subscribe to MA, can someone enlighten me about that article, please?
Re: Mopar Muscle article [Re: 70duster340] #1049725
08/12/11 02:07 AM
08/12/11 02:07 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
It was in a "Quick Tech" segment. The gist of the article was that points style ignitions should continue to use the ballast resistor to keep from damaging or prematurely wearing out the contact points. They also contend that the electronic systems did NOT need the ballast resistor. They suggest to tie the wires together at the ballast and enjoy a hotter spark with NO ill effects.
Re: Mopar Muscle article [Re: Kern Dog] #1049726
08/12/11 03:24 AM
08/12/11 03:24 AM
Cab_Burge Online work
Cab_Burge  Online Work
All of Mopar production cars with the ECU from the factory had ballst resitors, do you think maybe they where engineered that way for a good reason would you take the word of a magazine word geek over a engineer I don't
Re: Mopar Muscle article [Re: Cab_Burge] #1049727
08/12/11 04:38 AM
08/12/11 04:38 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
You see.... I was thinking the same thing. The article didn't go too deep into the explanation either. My Charger has the MP conversion, so does the FrankenDuster. I'm keeping them as is.
The Chrysler engineers decided to implement a different ballast when they integrated the electronic system in 1972. Why spend the $ to develop a new part if it was unnecessary? I'm not saying that the factory never made mistakes, but I'm going to "side" with the factory on this one.
Re: Mopar Muscle article [Re: Cab_Burge] #1049728
08/12/11 07:45 AM
08/12/11 07:45 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
They also engineered some degree of performance OUT of the engines in the name of "streetability" reliability and to lessen warranty claims.
by your theory, none of us should be changing cams, heads, intake manifolds, etc.
My understanding of the issue, is that the older coils were designed to run on 6-8 volts. this ensured they had enough voltage available to make a hot enough spark while the starter was sucking the battery juice to crank the engine...since your system voltage drops from 12.5 down to 8-ish volts while cranking the engine. but a coil designed to run on 6-8 volts won't last very long when you start feeding it the 14 volts from a running engine with the alternator providing charge.
but on today's newer coils, they've designed them to run on 12-14v allowing you to eliminate the resistor for more volts to the coil, and more volts to your spark plugs.
Following that theory, I bought a new coil, old school orange box, no ballast resistor and proceeded to drive 4,000 street miles in all kinds of weather, over a 5 year period, and not once did I have a problem with the coil or orange box "burning out"
**Photobucket sucks**
Re: Mopar Muscle article [Re: Kern Dog] #1049729
08/12/11 12:26 PM
08/12/11 12:26 PM
SomeCarGuy Offline
SomeCarGuy  Offline
No, Eberg claimed you will overheat the ECU running no ballast. I don't think he has ever actually tried it, as what he said isn't the reality. I continue to think that overheating was a "possiblity" thrown out there way back when that has since become "fact" since nobody ever tested to see if that was the case.
Re: Mopar Muscle article [Re: SomeCarGuy] #1049730
08/12/11 03:25 PM
08/12/11 03:25 PM
IL
furious70 Offline
furious70  Offline
IL
I've never read a study on how long an OEM coil and ecu will run on 12v but it's indisputable that they were designed to run on 9v to provide better starting characteristics. Run any electrical device with more volts than it was designed for and it will work, how long would come down to how much of a safety factor was built into the original design.
70 Sport Fury
68 Charger
69 Coronet
72 RR
