300m check engine light #1049596
08/08/11 09:29 PM
08/08/11 09:29 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
My 2001 300m just turned over 100k last week. A few days later at about 100,220 miles the check engine light came on, first time since I bought the car with 17k on it.
Is the check engine light programmed to come on at about 100k to remind of the timing belt/ water pump service?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 300m check engine light [Re: GO_Fish] #1049597
08/08/11 10:08 PM
08/08/11 10:08 PM
ill
dennismopar73 Offline
ill
get the code read see what it says,
Re: 300m check engine light [Re: dennismopar73] #1049598
08/08/11 10:35 PM
08/08/11 10:35 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
I knew that answer was coming! I have an appointment to take the car for service tomorrow, wanted to know beforehand what I was in for.
Re: 300m check engine light [Re: GO_Fish] #1049599
08/08/11 11:04 PM
08/08/11 11:04 PM
Unfortunately back in New York
N
Nukechargerboy Online content
Nukechargerboy  Online Content
N
DO the on-off-on-off-on-off-on trick. p0446 is the gas cap.
Re: 300m check engine light [Re: Nukechargerboy] #1049600
08/08/11 11:07 PM
08/08/11 11:07 PM
Motown, Mi
P
PAULS_340 Offline
PAULS_340  Offline
P
Motown, Mi
In Michigan you can pull up to any AutoZone or Pepboys? and they will politely come out and put a mini computer reader thingy on you car and most times tell you what's wrong...for free.
The idea is that you go back inside and buy the part
Still looking for LM29H1B415501, '71 Demon 340
Re: 300m check engine light [Re: PAULS_340] #1049601
08/09/11 01:27 AM
08/09/11 01:27 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
They will tell you the code, but very seldom do they know the 20 step flow chart procedures for confirming fault of components, but they will for certain sell you a possible part at no risk to them. Post the code and seek advice here on the board vs trusting a code reader jockey.
Re: 300m check engine light [Re: wheelsup68dart] #1049602
08/09/11 09:07 AM
08/09/11 09:07 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree they just read the codes.they wont spend 3K for a scanner to actually see what is going on.Sometimes you get lucky and and sometimes you dont.Ive seen people spend all kinds of $$$ because they dont want to pay for a diag.Then after blowing $$$$ they pay to have it fixed right.Rocky
Chrysler Firepower
Re: 300m check engine light [Re: therocks] #1049603
08/09/11 07:39 PM
08/09/11 07:39 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
It threw two codes using the on/off, on/off, on/off sequence. One was P0340 which the shop manual listed as "no cam signal", so I supposed that meant cam position sensor was gone.
The other code I can't remember at the moment, "P16??" did not appear in the shop manual (at least it was not listed with the other possible codes). I'll get back to my notes tomorrow.
Re: 300m check engine light [Re: GO_Fish] #1049604
08/09/11 09:31 PM
08/09/11 09:31 PM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
Replace the cam sensor for the P0340.
Re: 300m check engine light [Re: MadMax58] #1049605
08/10/11 09:22 AM
08/10/11 09:22 AM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
The code I couldn't find in the shop manual was P1684.
Correct, new cam sensor cleared the P0340.
Re: 300m check engine light [Re: GO_Fish] #1049606
08/10/11 09:31 AM
08/10/11 09:31 AM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
okay, found P1684 means battery disconnected within the last 50 starts.
