fuel injection
#1049242
08/08/11 04:55 PM
08/08/11 04:55 PM
Posts: 114 napa ca
procharged 484
napa ca
hemi with c/s billet carb that makes over 900 hp at 8.9 pounds at 6500 rpm. want to go with electronic fuel injection any recomendations cant lode photos im a computer dummy
Re: fuel injection
[Re: procharged 484]
#1049244
08/08/11 09:10 PM
08/08/11 09:10 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Send me an email and I'll work up an estimate, but first some questions: * What's the intake manifold? * What style CS carb (4150 or 4500)? * What type of blower?
Lot's of EFI Hemis on my web site.
You would have to change your fuel system - I trust you knew that.
Web Site: www.fastmanefi.com email: richnedbal@msn.com
Re: fuel injection
[Re: Mopar_Rich]
#1049245
08/11/11 04:17 PM
08/11/11 04:17 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
When will EZ EFI work with boost?
Re: fuel injection
[Re: feets]
#1049246
08/11/11 04:31 PM
08/11/11 04:31 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
No it will not according to Rich.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
Re: fuel injection
[Re: feets]
#1049250
08/12/11 07:14 PM
08/12/11 07:14 PM
Mopar_Rich
Sonora CA
EZ-EFI: That's correct - no boost. Nor will it work with alternate fuels (E85), and it does not control ignition.
That's why I asked WHEN will it work with boost.
Opps - missed the "when" part. Sorry - No clue! No promises from FAST either. My opinion: Boosted motors almost always need close ignition timing and spark retard curves at higher boost levels. That's something the XFI 2.0 does well and the EZ just is not set up to do.
Re: fuel injection
[Re: Mopar_Rich]
#1049251
08/13/11 01:13 PM
08/13/11 01:13 PM
feets
Senior Management
Senior Management
Irving, TX
I can tune that stuff with my Electromotive TEC II but would like to modernize a wee bit. The problem is I can't justify the cost.
Re: fuel injection
[Re: Dragula]
#1049253
08/15/11 05:59 PM
08/15/11 05:59 PM
feets
Senior Management
Senior Management
Irving, TX
I already have a distributorless EFI system.
I'd like a newer system but it IS all about the cost.
Re: fuel injection
[Re: feets]
#1049254
08/15/11 10:52 PM
08/15/11 10:52 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Feets, If you want to sell the tec2 let me know!! I've been looking for another one for a long time. I'll help offset the cost of a new system.
Re: fuel injection
[Re: TRENDZ]
#1049255
08/16/11 08:58 PM
08/16/11 08:58 PM
feets
Senior Management
Senior Management
Irving, TX
You're killing me! The TEC2 is a pretty strong system but it has very little support and I HATE the way the wires connect. I've had constant trouble with a couple of those wires. If the car ever started running rough I'd jump out with my tiny screwdriver and tighten the wires again.
