fuel injection #1049242
08/08/11 04:55 PM
08/08/11 04:55 PM
napa ca
P
procharged 484 Offline OP
P
napa ca
hemi with c/s billet carb that makes over 900 hp at 8.9 pounds at 6500 rpm. want to go with electronic fuel injection any recomendations
cant lode photos im a computer dummy
Re: fuel injection [Re: procharged 484] #1049243
08/08/11 08:19 PM
08/08/11 08:19 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
FAST man EFI is a user here. He's top notch and great to deal with. I bought my FAST v2.0 from him and will tell everyone i can to use him.
Re: fuel injection [Re: procharged 484] #1049244
08/08/11 09:10 PM
08/08/11 09:10 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Send me an email and I'll work up an estimate, but first some questions:
* What's the intake manifold?
* What style CS carb (4150 or 4500)?
* What type of blower?
Lot's of EFI Hemis on my web site.
You would have to change your fuel system - I trust you knew that.
Web Site: www.fastmanefi.com
email: richnedbal@msn.com
Re: fuel injection [Re: Mopar_Rich] #1049245
08/11/11 04:17 PM
08/11/11 04:17 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
When will EZ EFI work with boost?
- Stu Harmon
Re: fuel injection [Re: feets] #1049246
08/11/11 04:31 PM
08/11/11 04:31 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
No it will not according to Rich.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: fuel injection [Re: kick_the_reverb] #1049247
08/11/11 07:44 PM
08/11/11 07:44 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
EZ-EFI:
That's correct - no boost. Nor will it work with alternate fuels (E85), and it does not control ignition.
Re: fuel injection [Re: Mopar_Rich] #1049248
08/12/11 01:33 PM
08/12/11 01:33 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I run classic FAST.
Re: fuel injection [Re: Mopar_Rich] #1049249
08/12/11 06:28 PM
08/12/11 06:28 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
EZ-EFI:
That's why I asked WHEN will it work with boost.
- Stu Harmon
Re: fuel injection [Re: feets] #1049250
08/12/11 07:14 PM
08/12/11 07:14 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
EZ-EFI:
Opps - missed the "when" part.
Sorry - No clue! No promises from FAST either.
My opinion: Boosted motors almost always need close ignition timing and spark retard curves at higher boost levels. That's something the XFI 2.0 does well and the EZ just is not set up to do.
Re: fuel injection [Re: Mopar_Rich] #1049251
08/13/11 01:13 PM
08/13/11 01:13 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I can tune that stuff with my Electromotive TEC II but would like to modernize a wee bit. The problem is I can't justify the cost.
- Stu Harmon
Re: fuel injection [Re: feets] #1049252
08/13/11 02:50 PM
08/13/11 02:50 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
EFI isn't about justifying the cost, its about a need to go to it. I have two different FAST systems on two vehicles, and I much prefer it to carbs...
Re: fuel injection [Re: Dragula] #1049253
08/15/11 05:59 PM
08/15/11 05:59 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I already have a distributorless EFI system.
I'd like a newer system but it IS all about the cost.
- Stu Harmon
Re: fuel injection [Re: feets] #1049254
08/15/11 10:52 PM
08/15/11 10:52 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Feets, If you want to sell the tec2 let me know!! I've been looking for another one for a long time. I'll help offset the cost of a new system.
Re: fuel injection [Re: TRENDZ] #1049255
08/16/11 08:58 PM
08/16/11 08:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You're killing me!
The TEC2 is a pretty strong system but it has very little support and I HATE the way the wires connect. I've had constant trouble with a couple of those wires.
If the car ever started running rough I'd jump out with my tiny screwdriver and tighten the wires again.
- Stu Harmon
