NOS dual point distributor. Help with part number plea #1049198
08/08/11 03:14 PM
08/08/11 03:14 PM
seattle
U
unsilenced1 Offline OP
U
seattle
Hello to everyone, this is my first post and I am a new member.
I have a distributor I believe to be 1971 but I don't have a 71 book. Could someone please help me look this up.
Chrysler part number 3438356
IBS-4019 AS 50
Then I also have the vacuum advance unit, it says
1 Piece
CH803
3514332
LEAD ASSY.
73691 973
Thanks in advance! Mike
Re: NOS dual point distributor. Help with part number plea [Re: unsilenced1] #1049199
08/08/11 03:49 PM
08/08/11 03:49 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
my book shows 3438356 is the 440-6 auto trans. dist. minus cap/rotor (replacement) after 01/01/70 B,J,R,W body - the 3514332 is the 71 440-6 vac advancew/retard - welcome aboard
Re: NOS dual point distributor. Help with part number plea [Re: shakerjoe] #1049200
08/08/11 04:12 PM
08/08/11 04:12 PM
seattle
U
U
seattle
thank you very much for the quick answer. So, this is for 1970 cars not 1971?
Also is it possible for the shaft to have pitting even though it is NOS?
Re: NOS dual point distributor. Help with part number plea [Re: unsilenced1] #1049201
08/08/11 04:25 PM
08/08/11 04:25 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
seems like it was siting on a shelf inside the titanic!
Re: NOS dual point distributor. Help with part number plea [Re: unsilenced1] #1049202
08/08/11 04:59 PM
08/08/11 04:59 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
dist. # is for a late 70 build (after 1/1/70 - according to the book) 71 is a 3438577 for both auto and manual - the vac advance # you provided is 440-6 71 only - that shaft doesn't look too NOS to me - pitted pretty bad - was the dist.ina box - any water damage to it if it was ?
Re: NOS dual point distributor. Help with part number plea [Re: unsilenced1] #1049203
08/08/11 05:11 PM
08/08/11 05:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What makes you think the part is NOS , that part was very rusted , what does the rest of it look like ?
Re: NOS dual point distributor. Help with part number plea [Re: shakerjoe] #1049204
08/08/11 05:13 PM
08/08/11 05:13 PM
seattle
U
U
seattle
The distributor looks NOS, all but the shaft. I guess the shaft could have been replaced along the way, but why? Why would someone rob an NOS shaft and replace with a pitted one? Are those shafts hardened steel? Are they machined? Here is a pic of the topside of the distributor.
Re: NOS dual point distributor. Help with part number plea [Re: unsilenced1] #1049205
08/08/11 05:22 PM
08/08/11 05:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That looks NOS , the shaft must have been in a box that got wet and no one ever dealt with it , one could replace the shaft to make it look like new again.
Re: NOS dual point distributor. Help with part number plea [Re: unsilenced1] #1049206
08/08/11 05:42 PM
08/08/11 05:42 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
not looking to stir up a hornets nest here - and hope I'm wrong - and have no problem admitting such - but a few years ago someone was reproing distributor tags, and the one on yours is a little different than the originals I've looked at - the "shoulders" that turn up toward the retaining screw look very sharp - I'm pretty sure one should be rounded - on the left side - I looked long and hard to find a correct one for my car - the tag on my dist. has a rounded shoulder on the left side and is original - are you sure it's nos from a dealer - the 3438356 I believe is a dealer replacement # and not a assembly line #, I think the assembly line # dist. is 3438349...maybe some other members will have some info handy
Re: NOS dual point distributor. Help with part number plea [Re: shakerjoe] #1049207
08/08/11 06:11 PM
08/08/11 06:11 PM
seattle
U
U
seattle
No, I want to know the truth about this thing.... so if you think the tag might be repop I need to know. I have a few dual points from different years and I took some pics just now that I will add. They don't look too different from the 1970 in question. The coating has worn off or is just different throughout the years. Here is a 67 hemi tag.
Re: NOS dual point distributor. Help with part number plea [Re: unsilenced1] #1049208
08/08/11 06:14 PM
08/08/11 06:14 PM
seattle
U
U
seattle
and a 68 440 dual point.....
Re: NOS dual point distributor. Help with part number plea [Re: unsilenced1] #1049209
08/08/11 06:16 PM
08/08/11 06:16 PM
seattle
U
U
seattle
and here is a 69 440 dual point.....
Re: NOS dual point distributor. Help with part number plea [Re: unsilenced1] #1049210
08/08/11 06:37 PM
08/08/11 06:37 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
the stamping of CHRYSLER looks different in the 440-6 tag as opposed to the others you provided - looks like a block of letters pounded in where the others are nicely spaced out - then again these things were run out ASAP without too much quality control as far as stamping - as evidenced in double taps and missed #'s like other items - do you suspect the tag yourself or the distributor - maybe I AM wrong...
Re: NOS dual point distributor. Help with part number plea [Re: shakerjoe] #1049211
08/08/11 07:58 PM
08/08/11 07:58 PM
seattle
U
U
seattle
Actually I don't suspect the tag or the distributor. I am hoping someone has seen pitting like this on a shaft and can tell me it is pitting or it is manufacture defect. To get pitting like that you would have to have serious residual rust yes?
Re: NOS dual point distributor. Help with part number plea [Re: unsilenced1] #1049212
08/08/11 09:27 PM
08/08/11 09:27 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The tag should be under the clip.
Now,which one is real ? Not hard to figure out.
Re: NOS dual point distributor. Help with part number plea [Re: 62maxwgn] #1049213
08/08/11 09:31 PM
08/08/11 09:31 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And an untouched original.
