What lubricant to use on a fuel tank grommet? #1048890
08/08/11 12:10 AM
08/08/11 12:10 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
What lubricant do you use on a fuel tank grommet?
Re: What lubricant to use on a fuel tank grommet? [Re: markz528] #1048891
08/08/11 12:19 AM
08/08/11 12:19 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
WD 40, white lithium, silicon anything that dosnt eat rubber...
I am truckless..
Re: What lubricant to use on a fuel tank grommet? [Re: markz528] #1048892
08/08/11 12:19 AM
08/08/11 12:19 AM
IN
ahy Offline
ahy  Offline
IN
I used silicone plumbers grease - recommended by my tank supplier. Its available at hardware and home improvement stores.
Re: What lubricant to use on a fuel tank grommet? [Re: ahy] #1048893
08/08/11 12:33 AM
08/08/11 12:33 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Lubriplate
Re: What lubricant to use on a fuel tank grommet? [Re: markz528] #1048894
08/08/11 01:05 AM
08/08/11 01:05 AM
Arizona
az426john Offline
az426john  Offline
Arizona
vasoline
Re: What lubricant to use on a fuel tank grommet? [Re: az426john] #1048895
08/08/11 01:24 AM
08/08/11 01:24 AM
Santa Clara , ca
ramcuda Offline
ramcuda  Offline
Santa Clara , ca
all the above
I used white lithium...
1965 Ply "RAMCUDA" got to see it!!!<--- Should sell it/
1970 Superbird <------ Just one big argument/
1980 Jeep CJ5 <--- Just wheel it/
2000 Dakota R/T <--- Should Drive it more/
2001 Dodge Caravan <----- Cant kill it/
2004 Dodge 2500 4dr DIZLE 4x4 <---- LOVE IT !!!
www.moparalley.org
Re: What lubricant to use on a fuel tank grommet? [Re: markz528] #1048896
08/08/11 10:04 AM
08/08/11 10:04 AM
Alaska
73rrak Offline
73rrak  Offline
Alaska
Armor all I use it when I install anything rubber to metal Radiator hoses, fuel lines, Grommets, whatever. Makes rubber parts slide on easy then it dries like glue after a couple hours and no leaks. If you ever had to fight with a " A-N " fitting shoot a little armor all on both pieces and it makes putting them together pretty simple...... It's the only thing armor all is good for ....
Re: What lubricant to use on a fuel tank grommet? [Re: 73rrak] #1048897
08/08/11 11:13 AM
08/08/11 11:13 AM
Re: What lubricant to use on a fuel tank grommet? [Re: markz528] #1048898
08/08/11 11:32 AM
08/08/11 11:32 AM
NY usa
540challenger Offline
NY usa
Dawn dish soap
