torsion bars? #1048842
08/07/11 10:44 PM
08/07/11 10:44 PM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
Can't keep the adjustment on my right front torsion bar, and it rides on the bump stop. It started a few weeks ago. I would crank the adjuster and it would stay up, but go for a ride and it goes back down. Any ideas?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: torsion bars? [Re: 1967dartgt] #1048843
08/07/11 11:07 PM
08/07/11 11:07 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i would think it is going to brake? unless the bolt is stripped. brad
Re: torsion bars? [Re: 1967dartgt] #1048844
08/07/11 11:35 PM
08/07/11 11:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Look at the back mount(trans cross member) and see if
its twisting that mount out... put a magic marker
mark on it and see if it move
Re: torsion bars? [Re: 1967dartgt] #1048845
08/08/11 12:10 AM
08/08/11 12:10 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I had the problem last year and it was my adjuster bolt and block were stripping. If it is not the rear mount as stated.
You may need the new T bar adjusters
http://chucker54.stores.yahoo.net/tobarad.html
Re: torsion bars? [Re: Dodgem] #1048846
08/08/11 12:53 AM
08/08/11 12:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A simple way to check the adjuster is... adjust
up the bar and paint a line around the threads
at the adjuster block... drive the car and check
to see if the line is pushed back... its stripped
Re: torsion bars? [Re: MR_P_BODY] #1048847
08/08/11 05:04 AM
08/08/11 05:04 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I'm glad you brought this up because mine is doing exactly the same. I thought it was just worn and needed replacing.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: torsion bars? [Re: deaks] #1048848
08/08/11 06:13 AM
08/08/11 06:13 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
weird..... me too.........my drivers side front seems to randomly lower......
Re: torsion bars? [Re: 493_DART] #1048849
08/08/11 08:49 AM
08/08/11 08:49 AM
Hilltown Pa
Hilltown Pa
No its not the adjusters, it stays in the same spot currently bottomed out. So I would just have to use a tach to weld the rear back together? Release all pressure and weld.
Re: torsion bars? [Re: 1967dartgt] #1048850
08/08/11 09:08 AM
08/08/11 09:08 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
What bars (size) are you running ?
I have .840 bars on my B body,,,,and it will "sag" over time,,,if the car sits for an extended period of time,,or after tying it down on the trailer....
I now keep the front end "jacked up" at home ( jack stands,,etc ),,,and also at the track will lift the front for a while after i take it off the trailer....
This has helped,,,and i have had to adjust it alot less.
For me,,,i think it's the very light weight bars,,,and the B body weight of my car....
I might put a stronger bar on mine this fall..
Re: torsion bars? [Re: 69CHARGERMD] #1048851
08/08/11 10:07 AM
08/08/11 10:07 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Mine doesn't sag over a period of time, it's run to run.
Mick
best 60ft 1.36
Re: torsion bars? [Re: 1967dartgt] #1048852
08/08/11 10:15 AM
08/08/11 10:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If it is the rear mount thats bad its pretty hard to
get it back into place... it needs to be indexed
again before you weld it otherwise you will run out
of adjuster... hopefully you can get a inclineometer
reading off the other side(I forget where the flat
should be)
Re: torsion bars? [Re: MR_P_BODY] #1048853
08/08/11 10:49 AM
08/08/11 10:49 AM
Hilltown Pa
Hilltown Pa
Ok p-body I gotcha match it up with the other side before welding. To the other people mine has the adjuster bottomed out with no more adjustment left and is sitting on bump stop.
Re: torsion bars? [Re: 1967dartgt] #1048854
08/08/11 12:06 PM
08/08/11 12:06 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
go see bobby at bigtime and take the rms outta the 68dart and be done you'll love it bro. 100lbs gone,torsion bars gone etc..
Re: torsion bars? [Re: 1967dartgt] #1048855
08/08/11 01:04 PM
08/08/11 01:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I had that problem w/the 810 bars in mine so I went to the 840`s and problem solved. Also, when I installed em in the past, I didn`t crank down on the lower controll arm enuff initially to get the most adjustement out of it so my adjuster was cranked all of the way in like yours.
