Were there different tags for 1969 and 1969 1/2 #1048834
08/07/11 10:03 PM
08/07/11 10:03 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
At a show today I saw 2 different fendertags for 1969 Roadrunners.
One was the convential starting with motor--trans and vin number.
The second tag and I saw it on a couple of cars started off with RM
Did they run a different tag for 1969 1/2 cars?
Re: Were there different tags for 1969 and 1969 1/2 [Re: Dart6pak] #1048835
08/07/11 10:09 PM
08/07/11 10:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It is from the different assembly plants & the way the did things. You likely saw a St. Louis tag (normal to most) & a Lynch Road Tag. (not normal to most of us)
All of the '69 sixpak / 6bbl cars came from Lynch Road.
Re: Were there different tags for 1969 and 1969 1/2 [Re: Alaskan_TA] #1048836
08/07/11 10:15 PM
08/07/11 10:15 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
Thanks for the info
