Ok I dont have the money for the evans wiring kit for about another month,and I want to try and get the Dart running. Ill show you pictures and tell you what I think they are and you can tell me if im wrong or right.
Ok This is the voltage regulator,and im guessing it a universal electronic kind to replace the old mechanical type.
This is a thin blue wire,I think it goes to the Ign part of the Voltage Reg.
This is a connector with a solid blue and a blue with white tracer wire going into it. I think this is supposed to go on the ballast resistor.
Finally,these are solid blue and brown wires,which I think are supposed to have a connector similar to above and should also connect to the ballast resistor.
