Front Disc Brakes Kits #1048653
08/07/11 03:27 PM
08/07/11 03:27 PM
las vegas
70AARcuda Offline OP
las vegas
Looking to buy from Disc Brake kit for a 71 Demon with the later control arms and spindles (73+).
Was looking at wilwood kits.....any comments or recommendations?
Wanting to get rid of the heavy OEM setup.
thanks.
Tony
70 AARCuda Vitamin C
Re: Front Disc Brakes Kits [Re: 70AARcuda] #1048654
08/07/11 03:31 PM
08/07/11 03:31 PM
AndyF Offline
AndyF  Offline
You can put Wilwood calipers directly onto the stock rotors. That saves about 20lbs and you don't have to replace everything.
Re: Front Disc Brakes Kits [Re: AndyF] #1048655
08/07/11 03:48 PM
08/07/11 03:48 PM
las vegas
las vegas
would you have the part number for the calipers as all i am finding the the complete kits..
Tony
Re: Front Disc Brakes Kits [Re: 70AARcuda] #1048656
08/07/11 06:31 PM
08/07/11 06:31 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I put Wilwoods on the front of my 71 Demon (10" drum originally) and it made a huge difference in stopping power.I used the HD brake kit,and a Mopar M/Cyl from Rick Ehrenberg.Everything bolted up great and as mentioned stops very well.
Nautilus Racing-
Re: Front Disc Brakes Kits [Re: 70AARcuda] #1048657
08/07/11 06:39 PM
08/07/11 06:39 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
I went with aerospace components and everything went together easy and is suppose to be slightly lighter than the wilwoods both kits would work well
Re: Front Disc Brakes Kits [Re: 70AARcuda] #1048658
08/07/11 06:41 PM
08/07/11 06:41 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Nice Wilwood adaptor bracket by AndyF: http://arengineering.com/caliper/wilwood/caliperframe.html
Wilwood Dynalite Caliper #120-6815: http://www.summitracing.com/parts/WIL-120-6815/
http://www.moparaction.com/Tech/archive/disc-calipers.html
