Jegs Electronic Conversion Kit #1048566
08/07/11 11:30 AM
08/07/11 11:30 AM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Hey Guys has anyone used Jegs small block Electronic Conversion Kit. I want to change from pionts to electronic ignition. The Mopar kits are $225 and the Jegs are $150. Just wondering if anyone has had any luck with them?
Thanks Scott!
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
Re: Jegs Electronic Conversion Kit [Re: ScottG] #1048567
08/07/11 12:24 PM
08/07/11 12:24 PM
Clarksville, Tennessee
monoptn Offline
mopar addict
monoptn  Offline
mopar addict
I bought a knockoff from proform one time. I bet proform makes JEGs kits.
I bought it and set aside for 6 months. When I went to put it on and I measured the gap between pickup and reluctor, it was obvious the distributor shaft was bent. I emailed proform and they replaced it for free, even though their short warranty had expired. The new one has worked like a charm for 3+ years.
Re: Jegs Electronic Conversion Kit [Re: ScottG] #1048568
08/07/11 01:24 PM
08/07/11 01:24 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
FWIW, I'm running the Mancini knock off conversion kit, it has not given me any trouble.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Jegs Electronic Conversion Kit [Re: GO_Fish] #1048569
08/07/11 01:47 PM
08/07/11 01:47 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
also FWIW, if i had to do it again i'd seriously look into a unit like this - http://www.procompelectronics.com/store/index.php?target=products&product_id=37477 and be done with all the boxes, wires and confusion.
Re: Jegs Electronic Conversion Kit [Re: mikemee1331] #1048570
08/07/11 04:04 PM
08/07/11 04:04 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I would strongly recommend that you bypass the ProComp stuff, it is low quality and junk..
But if you insist..
Here is the distributor and built-in electronic module for $44..
http://cgi.ebay.com/ebaymotors/MOPAR-DOD...#ht_5813wt_1167
Just my $0.02...
Re: Jegs Electronic Conversion Kit [Re: Sinitro] #1048571
08/07/11 06:17 PM
08/07/11 06:17 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
so i've heard..... wasn't promoting them but rather offering am alternative and couldn't readily find a link to another company making them for small block. not sure if FBO has them yet.
