rocker arm noise (harland sharp's)
#1048500
08/07/11 01:09 AM
08/07/11 01:09 AM
Posts: 162 monticello,ms
andy3965
monticello,ms
I have harland sharp 1.6 ratio rockers on my w2 econo heads on my 408 and they are very noisy!!! this is the first time i've ever run harland sharps and was just wondering if everyone else's were this noisy?
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Re: rocker arm noise (harland sharp's)
[Re: Bob_Coomer]
#1048503
08/07/11 01:21 AM
08/07/11 01:21 AM
andy3965
monticello,ms
thats definetaly the sound they make click,click,click. its a solid cam 248/253@.50,.594/.594 lift. valve lash is .12 int., 14 exh. using morel edm lifters.
[Re: andy3965]
#1048504
08/07/11 01:25 AM
08/07/11 01:25 AM
andy3965
monticello,ms
ive taken the valve covers off twice to check everything and i cant find them hitting anywhere. no witness marks on the valve covers or rockerarms themselves, plenty of clerance on the retainers also. the more rpms the motor turns the faster the click,click,click!!!
[Re: Bob_Coomer]
#1048507
08/07/11 01:37 AM
08/07/11 01:37 AM
andy3965
monticello,ms
its a custom cam from bullet cams that RyanJ spec'd for me.thats the lash the cam card specs. its cut on a 108 lobe center and installed at 104.
[Re: Bob_Coomer]
#1048509
08/07/11 01:44 AM
08/07/11 01:44 AM
andy3965
monticello,ms
it was a typing error!!!! its way past my bed time and my eyes and brain aint working too good right now!!! sorry!!!
[Re: andy3965]
#1048510
08/07/11 08:14 AM
08/07/11 08:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
How are you doing your lash... are you doing the valve open/close procedure or the MP way... it may be loose but the way you are checking it it might not show it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1048511
08/07/11 08:30 AM
08/07/11 08:30 AM
andy3965
monticello,ms
i do it the mopar performance way. i have the decal and follow it.
[Re: andy3965]
#1048512
08/07/11 08:36 AM
08/07/11 08:36 AM
MR_P_BODY
Doing it that way doesnt always get you on the base to set the lash... most or a lot of guys use the valve open/close procedure with better results on bigger cams... might want to do a search for that procedure ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1048513
08/07/11 08:40 AM
08/07/11 08:40 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
What kinda oil you use ? Dont know how clicky u are, i switched from rotella to brad penn and clicking was a lot less, my lash was same for each oil, for what its worth it made a diff for me , again, dont know how much valvetrain noise you have. And i know my lash was set perfectly , is this your first time with roller rockers?
[Re: MR_P_BODY]
#1048514
08/07/11 08:41 AM
08/07/11 08:41 AM
andy3965
monticello,ms
thanks, i will look it up and give it a try.
[Re: andy3965]
#1048518
08/07/11 07:43 PM
08/07/11 07:43 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Warm the motor up, drive it for 10 mintues or more so the oil and valve gear is warm or hot,remove the rocker cover on one side and set the first intake valve when that cylinders exhaust valve just starts to open when rotating the motor over using the starter, take your time and make sure the feeler gauge barely slides in, not slides in easily Then rotate the motort over until the intake valve opens all the way and strats to close, set the exhaust and go to the next cylinder, when in doubt do it over Once you get that side done put it back togaether and riun it some to warm the other side up some more, see if you hear a difference with one side and then do the other It takes a little time to get use to this method but it is the best way to set the lash on any big lift long duration lots of overlap camshaft Let us know your results, BTW if you where setting them cold setting them hot will probaly make them a little quieter ![](/ubbthreads/images/graemlins/luck.gif)
[Re: Cab_Burge]
#1048519
08/15/11 09:03 PM
08/15/11 09:03 PM
andy3965
monticello,ms
ok, i reset the lash using the valve open/closed method and the noise is reduced by about 50%. i had originaly set the lash with the mopar perfomance decal and i was suprised to fnd the lash very loose when i checked them before i reset them this time. i believe that yall maybe right when you say the mopar performance way doesnt work with big duration cams.
