What's the differences in the 66'/67'Satellites ? #1048444
08/06/11 10:46 PM
08/06/11 10:46 PM
Midwest
Sidewinder Offline OP
Midwest
I know the grilles are different in these 2 but what else is different on these 2?Are the body panels and interior the same?I'd appreciate any info.!
Re: What's the differences in the 66'/67'Satellites ? [Re: Sidewinder] #1048445
08/06/11 10:57 PM
08/06/11 10:57 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
There are quite a few subtle differences - where to start?
EXTERIOR: You said you know about the front. Otherwise:
- Trunk panel and tail lights totally diff.
- Side trim on a '67 is different. All aluminum and runs at a different height than '66's.
- I don't think '66's could be had with the directional light 'bullet' on top of the front QP's.
- Hood ornaments are different.
INTERIOR:
- The 'western scroll' on the door and rear QP panels run horizontal on a '66 and vertical on the '67s.
- Seats on a '66 had two strips of 'western scroll', the '67s only one.
- The speedo on a '67 doesn't have the plastic 'Plymouth' emblem covering the needle hub.
- Horn rings were diff. Hub emblems were red on '66s. Black on '67s.
OTHER MISC:
- '66s usually had single circuit brake MCs. '67s were dual.
There are sure to be other things.
-Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: What's the differences in the 66'/67'Satellites ? [Re: Sidewinder] #1048446
08/06/11 11:47 PM
08/06/11 11:47 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
turn signals are in front bumper on 67
chrome/plastic strips in 66 rear taillights
different side chrome
Re: What's the differences in the 66'/67'Satellites ? [Re: terzmo] #1048447
08/07/11 12:06 AM
08/07/11 12:06 AM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
67 dash frames and chrome trim are different due to the different(collapsible) steering column in 67
67 front fender splash shields are different than 67
66 consoles have a removable rear section,67 up was all one piece
66 tachs use a remote sending unit 67 up does not
wheel lip mouldings are different due to different side and rocker trim
Re: What's the differences in the 66'/67'Satellites ? [Re: terzmo] #1048448
08/07/11 12:08 AM
08/07/11 12:08 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Fender headlight buckets (welded in) are unique to each year.
Steel Wheels had 10 holes in 66, most 67's had 6
Steering wheels were unique to each year
Dash Clusters were unique to each year
Console tachs were unique to each year
Hub Caps/Wheels covers were unique to each year
Tires were unique to each year
................Heck it's A LOT easier listing what was the same as opposed to what's different!
Re: What's the differences in the 66'/67'Satellites ? [Re: ScottSmith_Harms] #1048449
08/07/11 01:52 PM
08/07/11 01:52 PM
Midwest
Midwest
There are alot more differences than I thought in them.Was there more 67's built than 66's and are there more aftermarket parts available for the 67's?How hard would it be to put a 66'grille into a 67'?Other than the wiring issues does the 2 grilles bolt up in the same place?
Re: What's the differences in the 66'/67'Satellites ? [Re: Sidewinder] #1048450
08/07/11 03:42 PM
08/07/11 03:42 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No grille swap without some major hacking. You'll need a front clip from either year to really do it right
Re: What's the differences in the 66'/67'Satellites ? [Re: ScottSmith_Harms] #1048451
08/07/11 04:35 PM
08/07/11 04:35 PM
Indiana
O
Osyman Offline
Osyman  Offline
O
Indiana
Hood latch and support, 67 had a park brake warning light in the dash, the back of the cluster on 66 has circular connector, 67 has 2 sets of pins. Window cranks changed
