Page 2 of 3 1 2 3
Re: Will a 3000lb electric wench [Re: HEMIFRED] #1048234
08/06/11 07:27 PM
08/06/11 07:27 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Mines only 120 lbs, and's been nothing but trouble, since I said, "I do."
Re: Will a 3000lb electric wench [Re: Aspen7695] #1048235
08/06/11 07:29 PM
08/06/11 07:29 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I use a 3000lb Superwinch to pull my 3250lb Duster on my open trailer. No problem at all.
Raul
Now on a more serious note, I have the same winch, and no problems at all.
Re: Will a 3000lb electric wench [Re: Bob_Coomer] #1048236
08/06/11 07:30 PM
08/06/11 07:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My ATV had a small wench which was 1500 maybe 2000 lbs rated. It pulled my Dakota onto a flat bed open trailer a few times... No problems... if a 3000 wench cant do this, its JUNK.. I would avoid the cheaper harbor freight type wench's.
Sorry... I've been using the cheap Harbor freight ones
for years.... I did just buy a new one because the
clutch is starting to slip..... cant see buying a
big dollar Warn when it sits MOST of the time
Re: Will a 3000lb electric wench [Re: MR_P_BODY] #1048237
08/06/11 07:51 PM
08/06/11 07:51 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Only reason I say this is cause my Father-In-Laws wench on his Yamaha Rhino is J.U.N.K wont even pull a ATV stuck in a mud hole the other day... It's hardly 6 months old..
Re: Will a 3000lb electric wench [Re: Bob_Coomer] #1048238
08/06/11 07:57 PM
08/06/11 07:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to pull my car in backwards all the time with
the cheapo HF unit but now I drive it in... that
cheapo lasted 8 years using it all the time... maybe
he got a bad one
Re: Will a 3000lb electric wench [Re: Bob_Coomer] #1048239
08/06/11 08:38 PM
08/06/11 08:38 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Yep, sure sounds like the wench I'm stuck with. My Super WINCH on the other hand, works hard, when asked.
Re: Will a 3000lb electric wench [Re: BloFish] #1048240
08/06/11 10:26 PM
08/06/11 10:26 PM
Does anyone want to go out on a limb and recommend a winch
I've had and used the 2500 lb Super Winches, 3500 lbs and 4500 lb. Super Winches in trailers, like most thing it is way better to have the bigger one I have a freind who bought one of the Harbor Freight 2500 or 3000 lb winches(I can't remerber which ) it work twice and quit pulling his 1964 Dodge 330 two door bracket car into his Pace 24 ft enclosed trailer with the noraml dove tail floor and door As Fred said, the 2500 lb winch would almost come to a complete stop pulling my old bracket Duster(3150 lbs with me in it, 2870 lbs without me ) into my Pace trailer with the normal dove tail floor, the 4500 lb one doesn't slow down at all One of my old booses ask me to rescue his 1967 Ford 3/4 ton pick up truck(empty) when it broke down out of town, the 3500 lb winch in that trailer struggle to pull his truck into my trailer Warn winches are very good also, according to all the off roaders around here
Re: Will a 3000lb electric wench [Re: Cab_Burge] #1048241
08/06/11 10:58 PM
08/06/11 10:58 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
If this is going in an enclosed trailer you won't have any problems with a 3000lb winch. I had a 2500lb warn winch in my enclosed and never had a problem my car weighed the same or more then yours. Another upgrade i recommend is change the steel winch cable to the synthetic rope, I had a steel cable break when the front tires bounced from trailer to door and luck for me my buddy was walking by to stop the car.
Kevin
Re: Will a 3000lb electric wench [Re: RATTRAP] #1048242
08/06/11 11:06 PM
08/06/11 11:06 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Most wenches I've used were in the 110-130 lb range
8.30's @3400 lbs
Re: Will a 3000lb electric wench [Re: RATTRAP] #1048243
08/06/11 11:30 PM
08/06/11 11:30 PM
CHI-TOWN
REHBERGERRACING Offline
Redenbacher Racing
Redenbacher Racing
CHI-TOWN
5000 LB Super Winch and winch away!!
Re: Will a 3000lb electric wench [Re: REHBERGERRACING] #1048244
08/07/11 12:04 AM
08/07/11 12:04 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I bought a Warn 8000 off of a widow selling stuff out of her garage for 150 bucks. It was missing the cover and the control handle. Ebay, control handle buy now 50 bucks, and Warn for the cover 60 bucks. I took the winch apart, cleaned and greased it. It works like a champ. With an 8000 lb warn, I have no worries.
Re: Will a 3000lb electric wench [Re: Mopar-Al] #1048245
08/07/11 12:15 AM
08/07/11 12:15 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Alyerpal and REHBERGER can wad their cars up, tear the wheels clean off of them...... and still get the car back in the trailer!
I have one of the Harbor Freight 3k winches...... see Freds story about taking a nap while getting the car back in the trailer.
Re: Will a 3000lb electric wench [Re: J_BODY] #1048246
08/07/11 12:52 AM
08/07/11 12:52 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I've had a cheapy 2000# HF unit for MANY years and it's still working fine. Not going to set any speed record with it.
It's pulled a C body on my trailer with two locked up front wheels.
Only bummer is the switch mechanism has gone on a bender
Re: Will a 3000lb electric wench [Re: RATTRAP] #1048247
08/07/11 12:56 AM
08/07/11 12:56 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Will a 3000lb electric wench Pull my 3400lb car onto a trailer?? What lb rating is the avarage every one uses
Yes, it will! I used the elcheapo $49.00 1500# winch from harbor freight for a few years, Like MrPBody did.
I only had to tow the 3000# race car onto the trailor once. But I used it many times to tow other heavier vehicals onto the same trailor at heavier weights, 4500+ or so.
The old El Cheapo $49.00 1500# winch from Harbor freight worked pretty good.
My newer El Cheapo $89.00 3000# winch from Harbor freight is a train wreck. The cable as it unspools binds up like you wouldnt believe. That was never a problem with the 1500# winch.
You get what you pay for! Winch cable speed is also a serious consideration.
As far as wenches, They need love too!
Dont we all get along?? Wrench and Wenches!
Re: Will a 3000lb electric wench [Re: Sport440] #1048248
08/07/11 11:07 AM
08/07/11 11:07 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
My cheap Harbor Freight 3000 lb winch not only pulls my dragster in but lets it out of the trailer. It may not be a high $$$ warn but still gets the job done.
Sport440,you need to keep tension on most winches as they unspool. Hopes this helps solve your problem.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Will a 3000lb electric wench [Re: MRMOPAR622] #1048249
08/07/11 12:44 PM
08/07/11 12:44 PM
out front
jerrya Offline
Comin to a Labor Day Telethon
jerrya  Offline
out front
If you use a snatch block, (another pulley to double line the cable) it will double what you can pull.
Man does not plan to fail... he fails to plan
Re: Will a 3000lb electric wench [Re: RATTRAP] #1048250
08/07/11 02:39 PM
08/07/11 02:39 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I use a 3000# superwinch all the time for my car/trailer. Most of the problems I have seen others have are wiring or battery related (they cheap out and undersize)
"Just a Bracket car dressed up like a streetcar"
Re: Will a 3000lb electric wench [Re: jerrya] #1048251
08/07/11 02:41 PM
08/07/11 02:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And at the same time it doubles the time to pull the
same distance..... but it will pull double the weight
Re: Will a 3000lb electric wench [Re: MR_P_BODY] #1048252
08/07/11 03:54 PM
08/07/11 03:54 PM
Iowa
coronetville Offline
Iowa
How much more [cost] is a 3000 winch vs a 4500 winch?
Re: Will a 3000lb electric wench [Re: coronetville] #1048253
08/07/11 05:30 PM
08/07/11 05:30 PM
Fort Worth, TX
Dago Red Offline
Dago Red  Offline
Fort Worth, TX
A 3000 lb wench is like a motor scooter: useful and fun, but just don't let your friends see you riding it....
If You Can't Be Good, At Least Be Colorful
Page 2 of 3 1 2 3
