adjustable rockers #1048203
08/06/11 03:17 PM
08/06/11 03:17 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..have read a thread or two showing is usually close enough.
..what if the push rods are a bit too long ..i.e. no threads showing after rocker adjusted?
..car will be street driven only.
Re: adjustable rockers [Re: can.al] #1048204
08/06/11 03:45 PM
08/06/11 03:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You might be closing off the oil hole to lube the tips
Re: adjustable rockers [Re: MR_P_BODY] #1048205
08/08/11 11:21 AM
08/08/11 11:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The cups hitting the rocker body at full lift ????
