Page 3 of 3 1 2 3
Re: Why Use Manifold Vacuum for Vacuum Advance Distributor? [Re: Crazy68Dart] #1048085
11/08/11 12:31 PM
11/08/11 12:31 PM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
I am assuming that the adjustable cans adjust the amount of advance, and not how much vacuum it takes to get full advance.
Just the opposite. The adjustment adds tension to the spring inside changing starting advance vacuum and delaying full advance. To adjust full advance a shim has to be placed between the arm and the stop(backside of the can)
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: Why Use Manifold Vacuum for Vacuum Advance Distribu [Re: runinonmt] #1048086
11/15/11 12:23 PM
11/15/11 12:23 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
When plumbing the vacuum line from the distributor to a manifold vacuum source, does it matter if I use an existing port on the back of my RPM intake or do I need to use the smaller manifold port on the carb?
I thought that I may have read somewhere that the intake port may not have as strong of a signal as the port on the carb due to it's larger orifice size.
Re: Why Use Manifold Vacuum for Vacuum Advance Distribu [Re: YO7_A66] #1048087
11/17/11 09:18 PM
11/17/11 09:18 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Probably no measurable difference due to the orafice size as its dead head (no flow). However, on a hot cam it would seem possible that lower rpm vacuum might not be as steady in a runner. If you see lots of evidence of reversion (carbon up into the intake) then that would be a clue that further from the valve would be smoother.
OTH if the cam is that hot, its unlikely the engine will really want manifold sourced vac advance...
Page 3 of 3 1 2 3
