My car fall on its face at the 1000 ft? UPDATE
#1047936
08/06/11 12:55 AM
08/06/11 12:55 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Finally got the car to the track for the first time tonight. 528 hemi challenger, 10.3 compression, 630/618 lift, 295 duration, iron heads with some mild clean up work, factory intake opened up, 2 original hemi afb's, 2 1/8 headers, 3.5 collectors to about 18" of pipe to 3.5" aero chambers, 727 ,foot brake, 3500 converter, 4.30 geared dana, 29" tire. I made 3 passes tonight with it. It's 60 foot was 1.607, which I'm fine with since I was only leaving at about 2800rpm. I wanted to get a feel for the car a bit before I leave harder. It pulls well up to about the 1/8th and falls on its face at about the 1000 foot. I'm in 3rd before the 1/8. 1st and 2nd pull strong to about 6500 where I was shifting at. It doesn't break up or miss or anything, it just falls flat on it's face and stops pulling. My plugs look really good. Where do I start? I'm at a loss here. 7.4 at 92mph 1/8 and 11.95 at 96 mph was my best 1/4 of the 3 passes.
Chris from New Jersey
Re: My car fall on its face at the 1000 ft? long
[Re: fig426]
#1047937
08/06/11 12:57 AM
08/06/11 12:57 AM
Triple Threat
Renton Washington
Sounds like its running out of fuel. What kind of fuel system do you have?
[Re: Triple Threat]
#1047939
08/06/11 01:06 AM
08/06/11 01:06 AM
fig426
East Coast, NJ
Holley blue pump with 1/2 inch (8an) line to a high flow filter, I forget the make, to a regulator under the hood that splits with 2, 3/8 lines (6an) lines, 1 going to each carb.
[Re: fig426]
#1047940
08/06/11 01:08 AM
08/06/11 01:08 AM
fig426
East Coast, NJ
The fuel cell "output" fitting is 8 or 10an, I'm not sure, but the line at the cell is definately an 8 (1/2 inch).
[Re: Cab_Burge]
#1047942
08/06/11 01:28 AM
08/06/11 01:28 AM
fig426
East Coast, NJ
The pump is about 12" from the fuel cell, and below it. Cell in the trunk, pump under the trunk. The filter is on the subframe connector. The filter is pretty big and made to go after the pump and although I don't remember the make of it, I do remember the flow rate on it was really high. I have not flow tested the system. Guess I know what I'll be doing tomorrow morning. Any numbers I should be shooting for? Less than so many gallons per minute is bad? I ask because our local speed shop closes at noon so if I'm buying a pump, I have to get it figured out by then. I want to get back to the track Sunday!!
[Re: Mopar-Al]
#1047945
08/06/11 04:03 AM
08/06/11 04:03 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
no mention of fuel pressure ????
home of the Sox and Martin Hemi Duster
[Re: fig426]
#1047946
08/06/11 10:19 AM
08/06/11 10:19 AM
Posts: 52,972 Romeo MI
MR_P_BODY
3 things come to mind, flow test it, fuel pressure, and those carbs only have a single inlet and bowl and they do have a tendency to empty the bowl at high revs
[Re: fig426]
#1047948
08/06/11 10:33 AM
08/06/11 10:33 AM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
I would try another filter between the cell and the pump. Your pump may not be strong enought to push the fuel through that filter. Also, because it's after the pump, you may have trash in the pump/lines(before the filter) hurting the flow.
[Re: MR_P_BODY]
#1047949
08/06/11 10:36 AM
08/06/11 10:36 AM
Posts: 2,177 ill
dennismopar73
ill
check fuel pressure have 7 1/2 # and only slight drop off at w o t may think about alittle better pump for the hp you have going and the amout of draw on the fuel system, also just for giggles, check your vent , do not want a restriction there as well,
[Re: fig426]
#1047952
08/06/11 02:03 PM
08/06/11 02:03 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
If you can fill a one gallon container in under 30 seconds you should be good for a 11 second car, BG use to have a flow chart on thier website saying that a nine second car needed one gallon in or under 20 seconds, 10 second was, maybe, 25 seconds My memory is horrible, maybe someone else on here knows of another site that has flow numbers for testing and will post a link or say where to go to The comment on the needles and seats is very apprpriate, I have gone through that on many carbs, a .110 needle and seat would starve the motor according the wide ban and a .120 was more than enough Good luck, fix it before you burn the motor up In other words lift if it noses over
[Re: Dodgem]
#1047954
08/06/11 06:26 PM
08/06/11 06:26 PM
fig426
East Coast, NJ
1 gallon in 45 seconds from the blue pump. Picked up a Holley 150 black pump today. It's flow rate is pretty good, came with a new regulator, and it's alcohol compatible if I ever decide to change over. Looking like rain for tomorrow so hopefully if it's dry Wednesday night I'll bring it up to Island for a few passes. http://www.holley.com/12-150.asp
[Re: topside]
#1047956
08/06/11 09:34 PM
08/06/11 09:34 PM
MR_P_BODY
Cab, I think you're about right on the secs/gal; I seem to recall that 20 secs/gal is good for a low-10-sec car. Fig, take a really good look at your spark plugs & check your float settings, and if there's any rubber hose in the system, make sure there aren't any internal cuts that can create a flap inside the hose that reduces the amount of fuel it can flow. If you're running a stock pickup, make sure the fuel isn't pulling away from it; on my Roadrunner, I added a length of suitable hose that lays on the bottom and extends rearward a bit inside the tank. My Duster uses a sump.
He's right on those numbers BUT those are a VERY GENERAL number... weight of the car comes into play... it takes more power to move a 3500# car to low 10s VS a 2500# car to the same... more power requires more fuel
[Re: MR_P_BODY]
#1047957
08/06/11 10:13 PM
08/06/11 10:13 PM
Cab_Burge
Lots of variables in this hot rodding business Lots of gremlins also
[Re: fig426]
#1047958
08/06/11 10:17 PM
08/06/11 10:17 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
45 seconds...
That can't be good..
Chris..
[Re: Chris'sBarracuda]
#1047959
08/07/11 12:26 PM
08/07/11 12:26 PM
fig426
East Coast, NJ
Island is rained out today. Gonna have to wait until Wednesday.
[Re: fig426]
#1047960
08/07/11 05:08 PM
08/07/11 05:08 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
do you have a fuel pressure gauge that you can see .Shoud be dropping at that point at losing HP . Fuel line, fuel filter bet is the issue as others have said .
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: fig426]
#1047962
08/07/11 06:52 PM
08/07/11 06:52 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
How long for the black pump to pump a gallon?
Old, tired, and sometimes broke down. Me, not my car...
[Re: fig426]
#1047972
08/08/11 06:51 PM
08/08/11 06:51 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
I see, I thought you where comparing a 140 GPH free flow black pump to a 110 GPH blue pump. I would still check it.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#1047973
08/08/11 10:56 PM
08/08/11 10:56 PM
Posts: 903 Saskatchewan, Canada
cudabin
Just to be sure, did you check the valve springs? I know you said it pulled strong in 1st and second, but I would check seat pressure and open pressure to be sure... I used to run 9.55 at 138 with nothing but a single Blue pump... Good luck, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: fig426]
#1047975
08/11/11 12:28 AM
08/11/11 12:28 AM
MR_P_BODY
Made 2 passes tonight with the new fuel pump. First one redlighted -.437. 12.01 at 118mph. Total mess of a start but it pulled strong throughout. Second run. 60 foot 1.705 . .1 slower than last week. 330' 4.844. 1/8 7.424 at 95.56mph. 1000' 9.647. 1/4 11.531 at 119.41mph. I did a bad burnout and spun 1st and second. Pulled strong through the lights at about 6400rpm. Have some other things to sort out, like me being the driver , but I think it should go into the high 10's. Also it runs like turds after I go through the traps. Seems like now it's loaded up with fuel. I'll play with the fuel pressure, maybe a return line. Thanks again to all of you for the help.
Good to hear it pulls all the way... set the pressure, set the floats and most likely you will have to do some jetting
[Re: fig426]
#1047977
08/11/11 11:10 AM
08/11/11 11:10 AM
Posts: 8,165 Left Coast
BobR
Left Coast
What kind of suspension and tires? There may be more to hooking the car than doing a good burnout.
[Re: deaks]
#1047979
08/11/11 03:23 PM
08/11/11 03:23 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Usually you have to lower the stock float level down when using the hi flo needle and seats. Jake
JAKES AUTOMOTIVE
[Re: RBDuster]
#1047981
08/11/11 06:48 PM
08/11/11 06:48 PM
fig426
East Coast, NJ
Yeah I'm looking forward to Monster Mopar!!! Am thinking about getting a pair of DOT slicks so I can run the street class too. I'm just going to sort out the car the way it is now to figure out if I can pull off a shorter tire. 29's now. As for the suspension, caltracs, monoleaf in the rear. Gonna lose the ranchos and put in a pair of other adjustables I have. Calvert front shocks. Won't be going again until next Friday and next Sunday. Have to work this weekend and next Wednesday.
