92 Cherokee Crank Position Sensor Spacer Thickness #1047717
08/05/11 06:42 PM
08/05/11 06:42 PM
PA
70Duster Offline OP
70Duster  Offline OP
PA
Need to install a new Crank Position Sensor in the '92 Cherokee. The new one (aftermarket) didn't come with a spacer. Does anyone know the correct thickness of the spacer so I can make one? Would a small piece of double sided tape be good to attach the spacer to the CPS?
Re: 92 Cherokee Crank Position Sensor Spacer Thickness [Re: 70Duster] #1047718
08/05/11 09:24 PM
08/05/11 09:24 PM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
A cigarrete pack thick piece works just fine
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: 92 Cherokee Crank Position Sensor Spacer Thickness [Re: sreinheimer] #1047719
08/05/11 10:11 PM
08/05/11 10:11 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
iirc the bolts are shouldered on the 4.0l to set the air gap you dont have any adjustment
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: 92 Cherokee Crank Position Sensor Spacer Thickness [Re: pnypwr] #1047720
08/06/11 04:01 PM
08/06/11 04:01 PM
PA
70Duster Offline OP
70Duster  Offline OP
PA
Just got done installing the CPS. The Chrysler (Jeep) shop manual stated you have to use a spacer to set the air gap, but you're right, the bolts have a shoulder that's a light slip fit with the holes on the CPS bracket, and it doesn't allow for any adjustment. Thanks.
