tell me about blowers #1047362
08/05/11 12:14 AM
08/05/11 12:14 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
as the Cuda project nears the end, i want to start my research for the next project, blown 426 gen 3 hemi for the challenger
i have been eyeing BDS and the stuff they have for bolting on a blower. is BDS any good? should i go 6-71 or 8-71? should my crank have 2 key ways? can a machine shop cut a crank for another key? tell me what else i need to know
Re: tell me about blowers [Re: sixpackgut] #1047363
08/05/11 12:23 AM
08/05/11 12:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Race or street... yes the crank can be cut for another
key... tell you what else you need to know.... well
it would be the big shiny thing on the top of the engine
Re: tell me about blowers [Re: MR_P_BODY] #1047364
08/05/11 12:29 AM
08/05/11 12:29 AM
Charleston
Charleston
street cruiser. i have heard or read that there would be less heat useing the bigger 8-71.
also, this wont be right away. i'm thinking i need to get the crank takin care of. probably put a mod man intake on it with 2 carbs for now. later when i have the cash i could just slap the blower right on the mod man
does this remotely sound like a plan of attack? i have to spend my money wisely
Re: tell me about blowers [Re: sixpackgut] #1047365
08/05/11 12:46 AM
08/05/11 12:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Being that its a street cruiser you dont care about
the low compression till you put the blower on...I
have a 8-71 that I was going to put on the Rampage but
its sort of a PITA to look around on the street(JMO)
Re: tell me about blowers [Re: sixpackgut] #1047366
08/05/11 01:55 AM
08/05/11 01:55 AM
Stay as far away as you can from BDS , Hampton, Weiand, Littlefield and a bunch of others are a lot better From personel experiences on three BDS street and strip blowers As far as the size I wouuld look at a 8:71 or even a 10:71, if it will fit, the bigger blower will make more pressure at a lower RPM, you won't have to spin the blower real fast to make boost in other words 7 lbs at 150 F at 3000 RPM is way better than 10 lbs at 190 F at 3000 RPM The faster you spin a roots type blower the more heat it will make, added heat makes detonation under boost There are coolers that can placed between the blower and the intake but most of them restrict the air flow and end up making less power at the same boost, a big interference in the middle IHTHs
Re: tell me about blowers [Re: sixpackgut] #1047367
08/05/11 07:51 AM
08/05/11 07:51 AM
Delray beach, Florida
P
Performance Only Offline
P
HAPPY BIRTHDAY
machine shop owner and engine builder
Re: tell me about blowers [Re: Performance Only] #1047368
08/05/11 09:15 AM
08/05/11 09:15 AM
Charleston
Charleston
HAPPY BIRTHDAY
Thanks. you buying me a 8-71?
Re: tell me about blowers [Re: Cab_Burge] #1047369
08/05/11 09:19 AM
08/05/11 09:19 AM
Charleston
Charleston
Stay as far away as you can from BDS, Hampton, Weiand, Littlefield and a bunch of others are a lot better From personel expereinces on three BDS street and strip blowers As far as the size I wouuld look at a 8:71 or even a 10:71, if it will fit, the bigger blower will make more pressure at a lower RPM, you won't have to spin the blower real fast to make boost in other words 7 lbs at 150 F at 3000 RPM is way better than 10 lbs at 190 F at 3000 RPM The faster you spin a roots type blower the more heat it will make, added heat makes detonatioon under boost There are coolers tp place between the blower and the intake but most of them restrict the air flow and end up making less power at the same boost, a big interference in the middle IHTHs
your 1st sentence is confusing. do just the BDS blower suck or what?
Re: tell me about blowers [Re: sixpackgut] #1047370
08/05/11 09:42 AM
08/05/11 09:42 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have had good luck with Craig at BDS on three seperate blowers. 1-was a 6-71, an 8-71, and lastly a 10-71, and none gave us any issues. I also purchased my FAST efi thru them way back when and they were great at supporting it. Can you be more specific about what was wrong with them?
Also to 6packgut, the modman intakes will support roots blowers, but I would look at a whipple and mount it on one of those intakes. Less heat, more boost, and just sick instant torque. They have one that is a direct replacement for a 6-71, but it might make a little too much boost for street. Also, there are you tube vids by a company that has been putting BDS blowers on these new Hemis and making 900hp on pump gas CMN motorsports I think...
Re: tell me about blowers [Re: Dragula] #1047371
08/05/11 09:57 AM
08/05/11 09:57 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Save up and call Roger at PSI. They have gas style screws that adapt nicely to carbs. Cooler charge and more power everywhere.
Miles ahead of a roots.
Re: tell me about blowers [Re: Dragula] #1047372
08/05/11 09:58 AM
08/05/11 09:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a Dyers 8-71... I want to send it back to them
for a freshen up and a polish job... I talked to them
a while back and it was pretty cheap for what I wanted done
Re: tell me about blowers [Re: MR_P_BODY] #1047373
08/05/11 11:18 AM
08/05/11 11:18 AM
Dragula Offline
Dragula  Offline
Re: tell me about blowers [Re: jim sciortino] #1047374
08/05/11 11:20 AM
08/05/11 11:20 AM
Charleston
Charleston
that sounds interesting
i would love a wipple but i dont want to mess with fuel injection
Re: tell me about blowers [Re: Dragula] #1047375
08/05/11 11:21 AM
08/05/11 11:21 AM
Charleston
Charleston
These!!
http://www.whipplesuperchargers.com/product.asp?ProdID=1232
oh snap. i like that!!
thanks for the link
Re: tell me about blowers [Re: sixpackgut] #1047376
08/05/11 11:23 AM
08/05/11 11:23 AM
Charleston
Charleston
These!!
thanks for the link
holy crap, the prices
Re: tell me about blowers [Re: sixpackgut] #1047377
08/05/11 11:34 AM
08/05/11 11:34 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
These!!
thanks for the link
Happy Belated Birthday Ray...
I saw those prices too!!..
I have a small roots type blower, Weiand, on my SB chevy...its a good street blower but makes a lot of heat...if its a wow factor that you are looking for, then all means go for that chunk sticking out of the hood...if not then a centrifugal type like a pro-charger with an inter cooler would be a great way to go...also have you thought about Turbos?
Re: tell me about blowers [Re: smokinwoody] #1047378
08/05/11 11:58 AM
08/05/11 11:58 AM
Charleston
Charleston
These!!
thanks for the link
thanks. your not belated. i'm 41 today
my friend in alabama wants to do twin turbos with the new holley management system. but it is more for the wow factor. the whole reason i built a guard rail car was to stop taking the challenger to the track. so 1000 hp isnt a priority but i guess it would be fun
Re: tell me about blowers [Re: sixpackgut] #1047379
08/05/11 01:04 PM
08/05/11 01:04 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
just thought i would add on the prices on twinscrews,they are expensive for a reason,the precision required machining the screws and housings are out of this world,they are incredibly tight without any parts touching mechanicly. just very slowly turning a twinscrew with the originalseals on the inlet and outlet will suck the inlet seal in and push the outlet seal out. not made in china is and understatement.
there is twinscrews available for singlecarb applications aswell as dualcarb applications (dont realy know what the front carb does on those,it cant work to its full use.) and injection.
Re: tell me about blowers [Re: 1Fast340] #1047380
08/05/11 01:27 PM
08/05/11 01:27 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have heard nothing but Good things about BDS, there is another blower Company, the blower shop, billet cases. and there about the same price as others,
http://www.theblowershop.com/
lets see some pictures of the cuda.
Re: tell me about blowers [Re: sixpackgut] #1047381
08/05/11 01:45 PM
08/05/11 01:45 PM
I edited my first post, I was not clear The first BDS blower leaked grease from the front seals, twice the second one siezed up on the dyno and he redid it saying it was a brand new blower when he brought it back I could see damage to the case and rotors when mounting the injector hat, it lost 5 lbs of boost in 15 minutes of operating it on the dyno while he was trying to dial in the EFI mapping I was pulled off of the project after that and the motor ended up with a Littlefiled 10:71 and ]Motech EFI No problems with Littlefields blowers I put another Littlefield 10:71 on a street and strip 426 hemi two years later and had absolutely zero issues That motor made 925 HP at 7300 RPM with 7 lbs. boost on CA pump gas
