75 d100 {{{ 408w2 is in and running }}}
#1047308
08/04/11 11:56 PM
08/04/11 11:56 PM
Posts: 162 monticello,ms
andy3965
monticello,ms
the w2 headed 408 is in and running!!!!! she made her maiden voyage this past weekend and she is wicked quick!!!! she's headed to the muffler shop tomorrow to have the dynomax ultraflo's installed. still got a few things to tidy up on her(mostly electrical). here's a pic of the engine bay
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Re: 75 d100 {{{ 408w2 is in and running }}}
[Re: andy3965]
#1047310
08/05/11 12:01 AM
08/05/11 12:01 AM
andy3965
monticello,ms
i really havent done anything to the body, she still looks like she's been rode hard and put away wet. i did find a decent front bumper and i put a mar-k rear rollpan on that i got from Allen(thedodgeboys)
[Re: maxwedge1]
#1047314
08/05/11 12:20 AM
08/05/11 12:20 AM
andy3965
monticello,ms
i dont know how much of a sleeper she'll be because when she is running she definetally sounds like a beast!!! she has a very healthly, lumpy idle.
a quick rundown of the combo '73 360 block bored .030 over 11.5:1 c.r. W2 long valve econos with harland sharp rockers lunati springs,comp retainers and locks, 2.02 1.60 valves bullet cams solid lifter cam 248/253@.50 .594/.594 lift edm lifters billet timing chain, cloyes timing chain tensioner victor W2 intake weisco forged flattop pistons scat h-beam rods mopar performance 4in crank internally ballanced hughes engines girdle moroso 8qt pan and pickup hv72 oilpump custom PTC 9.5in torque converter
[Re: scratchnfotraction]
#1047318
08/05/11 04:00 PM
08/05/11 04:00 PM
Posts: 3,903 Oregon
hooziewhatsit
11.5:1 compression? What gas do you need to feed that with? Any quench?
Videos!
[Re: goldmember]
#1047320
08/05/11 06:40 PM
08/05/11 06:40 PM
andy3965
monticello,ms
so far its running great with pump 93. not a hint of detenation. the pistons are .002 in the hole with 64cc combustion chambers. using a felpro 1008 head gasket that is .039 thick. i was worried that i was gonna have to mix a little race gas in it but it seems to be working just fine. i just drove it 20 miles home from the muffler shop after having the dynomax ultra flo's installed and she cruised along at 65 mph with 60lbs of oil pressure and the temp settled in at 190 degrees.
[Re: rickstershemi]
#1047322
08/05/11 07:04 PM
08/05/11 07:04 PM
andy3965
monticello,ms
rick, i havent checked it. i just went back and watched the video of your 408 and it is super nice. i love the dual carb setup, it is killer!!!!!! kinda wish i'd have went with an edelbrock carb, this holley has been a pain in the you know what!!! i'm having a little trouble getting her to idle. i cant get it to idle in park or neutral less than 1500 rpm, and as soon as i put it in gear and the rpms drop i have to keep my foot on the prddal or she will die!!!
[Re: andy3965]
#1047323
08/06/11 12:26 AM
08/06/11 12:26 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
I went with 2-500cfm AVS units and so far it idles nice at around 850rpm...but it's on the rich side....gots a little adjusting to do yet, but it's very responsive.....once it's in the car I will probably switch back to the progressive linkage.
What Holley are you running...?????
Rickster
[Re: rickstershemi]
#1047324
08/06/11 12:41 AM
08/06/11 12:41 AM
andy3965
monticello,ms
its a 850hp thats been worked by BLP (BO LAWS PERFORMANCE) i bought it used at a swap meet and it came with a flow sheet that says it flows 930 cfm. it was setup for circle track use so i rebuilt it and installed notched floats and jet extensions. im not that good tuning holley carbs and right now it has a 6.5 powervalve in the front and the rear powervalve is blocked off. jetting is 75 front and 79 rear. any suggestions?
[Re: andy3965]
#1047325
08/06/11 10:23 AM
08/06/11 10:23 AM
rickstershemi
The only suggestion I can offer in this situation is to get your hands on any basic carb known to be good and try it first
I have a brand new edelbrock 600 afb sitting on the shelf I could make you a good deal on.
Rickster
[Re: rickstershemi]
#1047326
08/06/11 11:03 AM
08/06/11 11:03 AM
andy3965
monticello,ms
i have an edelbrock 600 afb that was on the 318 that was in the truck before i swapped to the 408. but i really didnt figure it was near big enough
