Re: 69 Charger Instrument panel problem
[Re: FPD031]
#1047271
08/05/11 11:20 AM
08/05/11 11:20 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
The common denominator between the dash lights and the gauges is the printed circuit board. They all have a common ground. Now, do the dash lights over by the clock/tach and in between the tach/clock and speedo work? Those light bulbs are powered by individual orange wires. If that doesn't work, then you might have double troubles. Also, you may wish to doubel check or replace the voltage limiter for the dash gauges. 3 of the 4 run off the 5v feed it supplies. The amp gauge doesn't. If ALL the lights don't work and you've replaced or know the fuse in the fuse box works, then it might be the dimmer switch.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: FPD031]
#1047274
08/05/11 09:44 PM
08/05/11 09:44 PM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
The voltage limiter has nothing to do with the lights. They are completely unrelated.
For dash lights: Check Grounds, Check rheostat. Does your radio light up and do your courtesy lights work?
For gauges: I'm not sure if the Charger has an integral CVR or a seperate one. If seperate, change it. Same thing as above, check all grounds.
If CVR and ground checks out, ground temp sender lead underhood. If temp gauge rises, the sender is bad. Do the same for Oil Pressure. And again for fuel gauge.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
