Re: 2.7L V6 - What years to avoid?
[Re: DCM71cuda]
#1046684
08/03/11 09:52 PM
08/03/11 09:52 PM
Posts: 1,159 Cruising!
QuickDodge
Cruising!
Mopar started making improvements to the 2.7 in 2001. They made quite a few changes for 2002. I believe it was 2006 (perhaps) when some more improvements were made.
That said, NONE of them are great engines! If you must get one, I'd get an 2002 or newer. They need to have the waterpump and timing chain changed every 100,000 miles. That job is a pain and the parts are expensive.
Overall, the 2.7 is an expensive engine to maintain, it can be difficult to repair, it's underpowered in the Intrepids and Chargers, and it has earned it's lackluster reputation. I'd pick one of the better Mopar engines.
[Re: HotRodDave]
#1046685
08/03/11 10:06 PM
08/03/11 10:06 PM
Posts: 791 Bama
Randy..
Bama
All of them
Even the newer ones are sludging up
Xs100000000000000.
[Re: QuickDodge]
#1046687
08/04/11 06:55 AM
08/04/11 06:55 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Be aware if motor swapping that mopar changed the timing chain setup in 2000/2001 and the PCM will NOT run the engine if it sees the wrong cam signal which is part of the timing chain setup.
Happened in our shop after a motor swap, had to tear down the motor and swap chain setups.
[Re: gdonovan]
#1046688
08/04/11 10:59 PM
08/04/11 10:59 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
I've got an '06 Charger with the 2.7L - just turned 100K a few weeks ago. My car has the limited lifetime drivetrain warranty, but does the timing belt need to be changed around now? What if the belt fails & the motor craps? Would Chrysler still cover the engine, or is it considered routine maintenance & neglect if I don't have the belt changed?
So far, I've had NO engine problems at all & it's been a great car, except for some front suspension issues & the faulty shifter that got stuck in park. Got all this stuff fixed yesterday & today though. The shifter was a recall.
[Re: Sunroofcuda]
#1046689
08/04/11 11:03 PM
08/04/11 11:03 PM
Posts: 163 Winnipeg, MB
sreinheimer
Winnipeg, MB
2.7L has a timing chain not a belt. Not sure if they are recommended at a certain mileage or not.
69 Dodge Charger - first full resto
05 Dodge Magnum R/T
