29" tire on a duster! #1046417
08/03/11 02:22 AM
08/03/11 02:22 AM
junction city oregon
V
viperblue72 Offline OP
V
Can you normally run a 29" radial tire on a duster? I know I wouldn't try bias slicks taller than 28". But since a radial probably doesn't grow as much can I run bigger? Fwiw I do have the springs relocated and tubbed but the outer fender lip is stock. What you guys getting away with? I will run a 325/50/15 if something bigger won't fit.
Re: 29" tire on a duster! [Re: viperblue72] #1046418
08/03/11 02:24 AM
08/03/11 02:24 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
stock length rear? or narrowed
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 29" tire on a duster! [Re: viperblue72] #1046419
08/03/11 04:30 AM
08/03/11 04:30 AM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
71 Duster, narrowed and tubbed. Stock outer fender wells. I run a 29/12/15 bias slick. I have to be careful on the roll out though. Anything over 91 inches and I have problems. I did relocate and center the rear diff in the wheel wells.
Steve
Re: 29" tire on a duster! [Re: Stroker Scamp] #1046420
08/03/11 05:10 AM
08/03/11 05:10 AM
V
V
Strokerscamp I'm currently running an A-body 8 3/4 with moser axles. 15x10 welds
with 6.5 backspace. Current tires are 28x11.5 et drags. They fit very easily. I would like to run something a little bigger if possible. Something with a 12.5 tread width and 29 tall would fit. But my question is can I run a radial that tall or will it grow and hit my front fender lip at high speed.
Plus I don't really know all the drag radial size options. Thanks.
Re: 29" tire on a duster! [Re: viperblue72] #1046421
08/03/11 08:21 AM
08/03/11 08:21 AM
Western NY
maxi426 Offline
maxi426  Offline
Western NY
Radials don't grow as much, but they do grow. Just finished the paint touch up on my wheel well lip.
Re: 29" tire on a duster! [Re: viperblue72] #1046422
08/03/11 08:56 AM
08/03/11 08:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you have 5/8" clearance they shouldnt hit... IF
necessary you can put a spacer plate in front of the
front spring hanger to space the axle back some...
dont get carried away with this unless you change
the drive shaft length
Re: 29" tire on a duster! *DELETED* [Re: MR_P_BODY] #1046423
08/03/11 10:45 AM
08/03/11 10:45 AM
V
V
Post deleted by viperblue72
Re: 29" tire on a duster! [Re: viperblue72] #1046424
08/03/11 10:48 AM
08/03/11 10:48 AM
V
V
Mr P.
That won't work with the spring relocation kit as it does away with the stock mounts and is a matter of drilling 2 holes. Good idea otherwise though.
Looking at the mickey thompson radial sizes though and they pretty much go from a 28" tire to a 29.5 or 30". Not much in between.
Re: 29" tire on a duster! [Re: viperblue72] #1046425
08/03/11 04:40 PM
08/03/11 04:40 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
I have 30x9 Hoosier radial slicks on my car with stock wheelwell, spring location, and stock wheel tubs.
Re: 29" tire on a duster! [Re: moparguy7074] #1046426
08/03/11 05:46 PM
08/03/11 05:46 PM
V
V
How much did you have to move your rearend back?
Re: 29" tire on a duster! [Re: viperblue72] #1046427
08/03/11 07:22 PM
08/03/11 07:22 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
i had my springs moved in and ran a 10" rim with 29/10.5w on my duster mini tubbed ..rear in stock loc.
Re: 29" tire on a duster! [Re: earthmover] #1046428
08/03/11 08:13 PM
08/03/11 08:13 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I have the Hoosier 30x10.5 radial slicks. They have a 92.5 cir and are smaller than my 29.5X10.5 M/T`s. I`ll try again later to post a pic.
Re: 29" tire on a duster! [Re: Dap] #1046429
08/03/11 11:55 PM
08/03/11 11:55 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
29.5 10.5 15 m/t,s on a 10 inch rim 5 inch bacspacing
stock location caltrac setup not minitubbed
1.39 9.85 - 137 mph
