which end it broke on will determine how to open the hood.
if it broke at the pull handle you can cut the housing back to expose some of the cable clamp the vice grips on the cable and pull
if at the latch end some time you can get to it under the van with a long screw driver and move the latch and some times can sneak in at the front of the hood
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
