I just fired this motor up for the first time in March; Fresh mild 360, new Edelbrock AVS carb (1806) that's worked great till now. First time this happened was the weekend of Carlisle. I jumped on the gas and the throttle stuck to about 1/3 open. I popped the throttle and it went back to idle. Since then, it's gotten progressively worse, now sticking at 1/3 throttle pretty much any time I put the pedal down over 1/2 and ease out of it.
The cable and kickdown linkage are running free. No problem there. I disconnected all linkage and moved the throttle plates open and closed. It seems to have a bind between the primary and secondary linkages that causes a "clicking" or catch spot that seems to match where the throttle would be when it "sticks". I've not removed the carb yet to check things out. Just thought I'd ask some opinions on here first.
Oh, and let's not make this an Eddy bashing thread, please. I like the Eddy.
Thanks, Guys!
