Steering column removal #1045526
08/02/11 12:50 AM
08/02/11 12:50 AM
MO
K
KN340 Offline OP
KN340  Offline OP
K
MO
Sorry if this has been asked before but changing the ingnition switch and I cant get past this. How the bleep bleep to you get this off? Special tool? Thanks for any replies.
Re: Steering column removal [Re: KN340] #1045527
08/02/11 01:31 AM
08/02/11 01:31 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I can't see the pic very well on my phone but I think you need to remove the C clip from the shaft with some snap ring pliers
Re: Steering column removal [Re: Tom_440] #1045528
08/02/11 02:57 AM
08/02/11 02:57 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
That is what it looks like to me too. You can remove the C-clip with a flathead and pliers, but it's a pain, and the clip can go a flyin and you may need to re-use it. I don't know about earlier columns, but if it is like the one in my 80's Gran Fury be careful with the bearings. On my GF those bearings are not encased in anything, and if you don't keep the shaft pulled up it will drop a tiny bit and the bearings will start falling out, and are impossible to get back in. Unfortunately, all the bad things that I mentioned can happen happened to me. Live and learn.
Re: Steering column removal [Re: KN340] #1045529
08/02/11 08:15 AM
08/02/11 08:15 AM
MO
K
KN340 Offline OP
KN340  Offline OP
K
MO
Is there more than one clip? I removed one and took out the seal but dont see anything else but the bearings.
Re: Steering column removal [Re: KN340] #1045530
08/02/11 09:41 AM
08/02/11 09:41 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
I had to pry on my column quit a bit to get it to come apart. I figure the two halves of yours are just stuck together like mine were. I didn't think of it at the time; but some penetrating oil applied where the collars meet may free them up.
*EDIT* I didn't make it clear that you have to separate the collars before the column will come completely apart.
P.S. - Once you have the collars apart, take some fine grit sand paper and sand the surfaces of the collars where they meet. Just enough for some extra clearance.
Re: Steering column removal [Re: bigsbigelow] #1045531
08/02/11 04:55 PM
08/02/11 04:55 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I only had one clip in my column. I got down as far as the bearings and stopped there. I was going to replace my ignition but once I lost the bearings I stopped at that point.
Facts are stubborn things.
