One good run and then #1045140
08/01/11 07:00 PM
08/01/11 07:00 PM
South Jersey, NJ
DragDart360 Offline OP
South Jersey, NJ
I bought these for a lesser built engine and thought I could use then on this one WRONG one run then:(
Luckily no major damage to other parts, I will buy a new rocker set not just replace the shaft.
What to buy? Hughes, T&D, Other?
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: One good run and then [Re: DragDart360] #1045141
08/01/11 07:10 PM
08/01/11 07:10 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
Harlands Thats a scary lookin pic!
Re: One good run and then [Re: Thor500] #1045142
08/01/11 07:19 PM
08/01/11 07:19 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
OUCH!!!!!!!
Re: One good run and then [Re: MIKES_DUSTER] #1045143
08/01/11 07:23 PM
08/01/11 07:23 PM
tboomer Online work
tboomer  Online Work
Awww...Man that sucks!
Re: One good run and then [Re: tboomer] #1045144
08/01/11 07:29 PM
08/01/11 07:29 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
I would not be too quick to blame the rockers. What type of hold-downs were used?
Re: One good run and then [Re: DragDart360] #1045145
08/01/11 07:38 PM
08/01/11 07:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would ask whats the open pressure and the RPM
Re: One good run and then [Re: DragDart360] #1045146
08/01/11 07:46 PM
08/01/11 07:46 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I had it happen to crane gold race rockers and it was because the bolts came loose.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: One good run and then [Re: 1967dartgt] #1045147
08/01/11 07:59 PM
08/01/11 07:59 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Been there, done that, went to Harlands
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: One good run and then [Re: DragDart360] #1045148
08/01/11 08:48 PM
08/01/11 08:48 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
i think when tigthening down rocker shafts with high spring pressure they all flex no mater how carful you are and sooner or later they brake at the weak point..the bolt ..sean it afew times..just my
Re: One good run and then [Re: Plymouth340] #1045149
08/01/11 09:19 PM
08/01/11 09:19 PM
South Jersey, NJ
South Jersey, NJ
I don't know the open pressure, they are PSI roller springs, the highest RPM was 6500. I followed the link about us cheap Mopar guys after I thought I could use this Chinese stuff. I got lucky and got away with no major damage. The hold downs were Hughes with studs torqued per Hughes recommendation. Nothing I received from PRW was any good, I haven't even got a refund for the damper that didn't fit. Hopefully the flexplate won't shatter on the next run.
Re: One good run and then [Re: Plymouth340] #1045150
08/01/11 09:45 PM
08/01/11 09:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my W-2 heads I turn each nut a 1/4 turn till tight...
takes a while but I never broke a shaft
Re: One good run and then [Re: Plymouth340] #1045151
08/01/11 09:48 PM
08/01/11 09:48 PM
tboomer Online work
tboomer  Online Work
Plymouth 340...Check your e-mail!!
Re: One good run and then [Re: tboomer] #1045152
08/01/11 10:14 PM
08/01/11 10:14 PM
You really lucked out in not hurting anything.
Re: One good run and then [Re: DragDart360] #1045153
08/01/11 10:53 PM
08/01/11 10:53 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Those rockers dont belong on any engine with roller cam and springs. They just arent capable or of high enough quality for that. You cant ( sort of) blame the rockers, they were mis-applied sorry to say.
Check your PMs.
RIP Monte Smith
Re: One good run and then [Re: Plymouth340] #1045154
08/02/11 05:28 AM
08/02/11 05:28 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Had that happen to harland sharps shafts.
Bought some cheap mancini shafts witch seem to hold up fine.
I would think the hold downs came loose.
I know the shfts in the prw kit is good/not any worse than some else
