Page 11 of 12 1 2 9 10 11 12
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044725
05/25/14 10:58 PM
05/25/14 10:58 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Started on the skid plates
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044726
05/25/14 10:59 PM
05/25/14 10:59 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
And installed the driveshafts
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044727
05/25/14 11:00 PM
05/25/14 11:00 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The rear driveshaft has to be shortened about 1.5"
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044728
05/28/14 06:35 PM
05/28/14 06:35 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
doors are finished, I welded on a threaded plate for the 03-06 TJ Wrangler mirrors. I also did a quickie patch on the lower 1/3 of the doors with some replacement panels.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044729
05/28/14 06:36 PM
05/28/14 06:36 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I had to mount the mirrors back far enough to clear the vent windows.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044730
05/31/14 03:15 PM
05/31/14 03:15 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Tailpipe is made, still have to do the hangers though
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044731
05/31/14 03:16 PM
05/31/14 03:16 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The Mustang master cylinder is too small for the 1-ton brakes, so I installed a GM K3500 truck unit this morning.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044732
06/03/14 06:39 PM
06/03/14 06:39 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Transfer case skid is painted and installed
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044733
06/03/14 06:47 PM
06/03/14 06:47 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Seat belts are installed, pinion angle set and perches welded, brakes are bled, alignment is done, and Tom drove it around the yard under its own power for the first time since he has owned it!!
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044734
06/09/14 07:21 PM
06/09/14 07:21 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Tranny pan skid is done
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044735
06/09/14 07:23 PM
06/09/14 07:23 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I finished the Wagon. Shocks are behind schedule, but Tom knows how to install those .
Off for a VIN check tomorrow for registration.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044736
06/10/14 08:26 PM
06/10/14 08:26 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
What a beast!!! Cool!!!
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: "TastyKake" - Willys Wagon Build [Re: 11secdart] #1044737
06/10/14 09:20 PM
06/10/14 09:20 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Thank you, and now it is registered as well
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044738
06/12/14 11:15 AM
06/12/14 11:15 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
http://youtu.be/F_46WjpA2ak
I drove the Wagon to work today as well
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044739
06/15/14 02:54 PM
06/15/14 02:54 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Tom and I took the Wagon out for some light wheeling. Our friends Jim and George joined us in their Land Rover Defender.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044740
06/15/14 02:59 PM
06/15/14 02:59 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
We found out the Wagon is so heavy that it has trouble on steep hills even in 4lo. AND that a super heavy rig is too much for the Selectros. I had been warned but was determined to try them since my axle (originally built for my M37) has a mechanical locker up front. Tom blew it up real fast on a small ditch...
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044741
06/15/14 03:00 PM
06/15/14 03:00 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Came off in sections...
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044742
06/15/14 03:02 PM
06/15/14 03:02 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
So I gave Tom my solid hubs. Now I am down more parts for my vehicles We drove the truck to see how it handled the locker. To my surprise it drove like an open diff. So the solid hubs and mechanical locker are staying
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044743
06/15/14 07:49 PM
06/15/14 07:49 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
After blowing up my selecros I also just use the stock drive flanges. For driveing down the road I have a set of aluminum bicknel flanges of a dirt track car with the splines boared out to keep the dirt out. When I get where im going I just take out the bolts and swap them out. If you change the hub out to the 91-93 dodge style they are the same as a chevy and there are alot more options of locking hubs.
Re: "TastyKake" - Willys Wagon Build [Re: NoFrills] #1044744
06/15/14 10:27 PM
06/15/14 10:27 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Tom has a set off of his '92 axle, but he sold the Warn selectors. I had gotten him a set of Solid 35spline slugs for them, because he was suppose to get an ARB.
