Page 4 of 12 1 2 3 4 5 6 11 12
Re: "TastyKake" - Willys Wagon Build [Re: dynotune440] #1044585
08/04/13 12:10 PM
08/04/13 12:10 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Any bracing or support planned for the steering box?From the pictures provided it looks like with serious off-road use it will end up flapping in the wind. http://www.polyperformance.com/shop/Syne...00-p-29632.html
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044586
08/04/13 12:14 PM
08/04/13 12:14 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Jeep Build - For Off Roading and MPG [Re: Rug_Trucker] #1044587
08/04/13 01:22 PM
08/04/13 01:22 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
It's not finished yet, I just wanted to get it in position. I will build a box to house the tubes for the lower mounts.
Re: "TastyKake" - Willys Wagon Build [Re: Geezer] #1044588
08/04/13 05:47 PM
08/04/13 05:47 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Fuel tank is mounted.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044589
08/04/13 05:48 PM
08/04/13 05:48 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The fuel tank is a CJ7 15 gallon poly tank, I will be switching it to a Pre-'80 tank in order to get the larger inlet which will be needed for the output of the diesel pumps.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044590
08/04/13 05:50 PM
08/04/13 05:50 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The skid plate is from Max-Bilt, I actually mounted it backwards so that the high bolts are in the rear.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044591
08/04/13 06:03 PM
08/04/13 06:03 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I still need to do some finish welding on the bottom, but that will wait until I have all of the stuff mounted from the top that required the axles to be in place for mock up.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044592
08/08/13 09:05 PM
08/08/13 09:05 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That should do 30+ mpg especially if you put on an air to air aftercooler and gear it accordingly.
Kevin
Re: "TastyKake" - Willys Wagon Build [Re: Twostick] #1044593
08/18/13 02:18 PM
08/18/13 02:18 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
It will have a small intercooler in front of the radiator and the axles have 4.10 gears with 37" tires, plus the tranny has overdrive.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044594
08/18/13 03:39 PM
08/18/13 03:39 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I finished boxing the step in the frame... it won't be flexing here
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044595
08/18/13 03:40 PM
08/18/13 03:40 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
"A smart fellow could put his knee up on such a step."
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044596
08/18/13 03:41 PM
08/18/13 03:41 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Shock towers came in from RuffStuff. I will hold off on welding them on until after the body is on and the nose is positioned.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044597
08/18/13 03:42 PM
08/18/13 03:42 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I finished making the outside rear bumper reinforcements, I had to keep them a little narrow to fit within the qtr panels
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044598
08/18/13 03:43 PM
08/18/13 03:43 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I also made the rear shock crossmember
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044599
08/18/13 07:59 PM
08/18/13 07:59 PM
ohio
all spooled up Offline
ohio
that is some nice fab work
Re: "TastyKake" - Willys Wagon Build [Re: all spooled up] #1044600
08/19/13 07:18 AM
08/19/13 07:18 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Thank you
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044601
08/24/13 02:31 PM
08/24/13 02:31 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Fabricating the lower steering box mounts
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044602
08/24/13 02:32 PM
08/24/13 02:32 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
And some plate to make it purdy
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044603
08/24/13 06:21 PM
08/24/13 06:21 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
and welded
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044604
08/24/13 06:23 PM
08/24/13 06:23 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Frame is now upright and ready to start assembling and painting as I go (with brush on paint)
