suspension help #1044507
08/01/11 11:10 AM
08/01/11 11:10 AM
Muskegon Mi
dcr Offline OP
dcr  Offline OP
Muskegon Mi
One more issue with car this weekend at martin car has not moved in 20 years under its own power has ss springs and nothing special shocks and runs 10.35 @129.86 best 60fts 1.47 @ 3145 lbs with 33x10.5 tire I dont have any picts to post but if you were at martin it was dark green 70 duster.First pass left at idle and car pulled right with tires in air brought it back and softened left frt torsion bar leaves straight now but twist to right so bad it looks like a gm a or g body. Is there anything can be done about this or is it the nature of the beast.Thanks Dan
Re: suspension help [Re: dcr] #1044508
08/01/11 11:19 AM
08/01/11 11:19 AM
Muskegon Mi
dcr Offline OP
dcr  Offline OP
Muskegon Mi
Sorry I should have posted tis inthe race section Is there a way I can move it?
Re: suspension help [Re: dcr] #1044509
08/01/11 01:05 PM
08/01/11 01:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
air shock on the right rear (pass) like the old days to pre load that corner. I've done it works.
Re: suspension help [Re: Dodgem] #1044510
08/01/11 01:13 PM
08/01/11 01:13 PM
Muskegon Mi
dcr Offline OP
dcr  Offline OP
Muskegon Mi
I was thinking along those line also I have a coil over load leval spring that goes over the shock kinda low budget but may just work dont wanna spend to much because I may ladder bar car but then again it works well with ss springs
