Re: hemi build up? [Re: FASTFISH420] #104432
02/14/09 09:33 PM
02/14/09 09:33 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
hello?where are all the hemi guys?
The is the HOT-STREET Hemi I built for the book that will be released in June (How to Build a Max-Performance Hemi". This picture shows EFI but carbs work just as as well.
It's also shows coil-on-plug but a distributor would work just fine too.
This is a 572" Hemi:
800 RPM idle at 14" vacuum
700 ft lbs at 3500 RPM (curve was very flat)
725 HP at 6200.
On 91 octane but it should be fine with 87 or 89, just haven't tried that yet.
World block, unported Stage-V heads.
With a hydraulic roller would be virtually maintenance free.
Re: hemi build up? [Re: Mopar_Rich] #104433
02/14/09 09:45 PM
02/14/09 09:45 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
World block, Scat 4.5" crank, 9.5: pistons, etc...
Typical rotating assembly - nothing trick or expensive.
The only "special stuff" to the basic motor was:
* A very smooth plateau-hone using a gapless top ring and a "hooked groove" second. (Yes - the hone was more expensive to do). Pistons install with a "seating powder" not WD40 or oil.
* Cam specs are different, but not any more expensive.
* Heads only had a valve job.
* KB rocker stands and Comp valve train.
* Used a new "reverse flow" water pump from Meziere. (Had to drill air-bleed holes in the heads to use reverse flow).
This rings seated in 10 minutes and have produced very good results for me for a street engine. Other engines I've built with these rings really keep the oil clean after many miles. Leak down is nil.
The cam has a very wide lobe separation (114-116) with nominal lift (.600). Durations are 240-ish intake and 250-ish exhaust (@ .050). This is what gives this engine such good manners from idle on.
Re: hemi build up? [Re: Mopar_Rich] #104434
02/14/09 10:04 PM
02/14/09 10:04 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
You can go really inexpensive if 800 is really where you want to be. Going forced will pile the dollars on right along with the power. To save every buck you can here's what I'd do.
Scat 4.5 crank
H beam 7.1 rod
11.5:1 piston from any of the big companies with a standard 1/16 1/16 3/16 moly ring package
SV replacement head with basic port work (bowls-port entry stuff) stainless valves
Indy roller rockers on steel stands
mega, or world block Iron. Move the pickup over and use 5/8 pickup, keep it internal for cost.
solid flat tappet with chain drive
Indy small plenum 4500 single 4
OTB holley 1050
steel tray and milodon pan
It'll make over 800 and be about as cheap as you can go. Going forced means throw all that out the window and get ready to get off the hip
Re: hemi build up? [Re: dthemi] #104435
02/15/09 12:11 AM
02/15/09 12:11 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
My build is similar to others here. 572"
World aluminum block
Block honed and prepped @ FHO for CP 10.5 pistons
Diamond rings
Stage V replacement heads CNC ported @ MCH
Stage V rockers T&D shafts, Hi Tech stands
K1 crank
K1 7.100 rods
Comp solid FT Nitrided and using Howard's EDM lifters
.620" .630" 258* and 263* @ .050 108 LSA
Milodon dual swinging pu pan HV pump
MP cross ram with FHO lids or Indy single intake
Probably 2 770 SS carbs
MP tach drive dist.
Chain drive for cam
MP water pump assy
I am not sure what HP level to expect.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: hemi build up? [Re: Hemi Allstate] #104436
02/15/09 12:49 PM
02/15/09 12:49 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
Hemi Allstate, Just wondering what the stage v cnced heads flowed after they were ported? Planning on building a 604ci hemi for my GTX and not sure which heads to buy.
Re: hemi build up? [Re: 604 Hemi GTX] #104437
02/15/09 01:06 PM
02/15/09 01:06 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I also used the Stage-V replacement heads. With only a good valve job and smoothing the seat areas (no additional porting) they flowed 388 (int)and 277 (exh), measured at .700 lift.
Re: hemi build up? [Re: 604 Hemi GTX] #104438
02/15/09 01:39 PM
02/15/09 01:39 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Contact Tim at FHO.
He's doing cnc'd stage v's. He has programs to get the replacement heads flowing 470cfm and his millenium heads flow almost 600cfm.
Re: hemi build up? [Re: The Shadow] #104439
02/15/09 03:00 PM
02/15/09 03:00 PM
ONTARIO,CANADA
ONTARIO,CANADA
WOW.....that's about what i was hoping for.Thanks
Re: hemi build up? [Re: 604 Hemi GTX] #104440
02/15/09 08:00 PM
02/15/09 08:00 PM
Mt. Eden Ky.
Mt. Eden Ky.
542GTX,
I would have to say that mine are not quite up to the numbers I am seeing posted here! That said, I am sure that they will get the job done. I know there are differences in flow benches as well.
Here is the specs.
1996 Ram 1500 Sport
1968 road runner
Re: hemi build up? [Re: Hemi Allstate] #104441
02/15/09 08:53 PM
02/15/09 08:53 PM
ONTARIO,CANADA
ONTARIO,CANADA
Thanks Hemi Allstate, Thats roughly what i would be hoping for. my motor will be a pump gas 604ci.
Re: hemi build up? [Re: 604 Hemi GTX] #104442
02/15/09 09:13 PM
02/15/09 09:13 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
New MP/Edelbrock castings
Re: hemi build up? [Re: Bob_Coomer] #104443
02/15/09 10:40 PM
02/15/09 10:40 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
I got a buddie that just bought in a package deal, a fresh 572 with all the goodies long block, with virgin Mopar heads separete, but the long block is very nice.. He maybe looking to broom !!
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
