Re: 68 RR steering column question
[Re: Birdturd]
#1044294
08/02/11 12:27 AM
08/02/11 12:27 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I have a 69 car and service manual. I needed to study all the steering columns, auto, manual, tilt, and Saginaw to understand what I needed to know. There is a cross sectional view of the lower end of the column in the tilt wheel section that seems to apply to all types (but not all the parts are labeled, unfortunately).
The 69 manual says for auto column,(5) Lube floor plate O ring w soap or rubber lube and slide floor plate assembly onto column. Floor plate MUST be installed before installing shift tube. (6) With DUST WASHER installed on shift tube, slide into jacket...
That dust washer apparently fits the OD of the shift tube as in the link you mentioned. Since it is hidden, I'd be inclined to make one out of scrap foam gasket material that you get with firewall and heater/AC gasket kits. Looks pretty low tech and high chances of success.
PM me if more info from the 69 manual might help.
[Re: Birdturd]
#1044304
08/04/11 12:10 AM
08/04/11 12:10 AM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
My column didnt even have that part on it, must have been scavenged before I got it?
This is the post with the '68 switch...
