hemi build up? #104412
08/13/08 06:59 PM
08/13/08 06:59 PM
Central,Ohio
FASTFISH420 Offline OP
Central,Ohio
I was thinking about building a pump gas hemi,that has some good cubic inch,something that is not going to break the bank,that is reliable,and makes good power.
The hemi builders can chime in and give me some ideas and maybe some $$$ options.never built a hemi.I have done the 572 wedge stuff and and the high end small block stuff,but never the hemi.
would like to be over 500 cube,cast or aluminum block?decent set of flowing heads.single cast manifold,dominator,pump gas friendly,maybe even possible pro-charger one day..what would be the best head to use?would like to make 800 horsepower.
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: hemi build up? [Re: FASTFISH420] #104413
08/13/08 08:05 PM
08/13/08 08:05 PM
Central,Ohio
Central,Ohio
hello?where are all the hemi guys?
Re: hemi build up? [Re: FASTFISH420] #104414
08/13/08 09:14 PM
08/13/08 09:14 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
if you can fork the coin, go for the aluminum block, KB is best. Stage V heads ported from Modern Cylinder Head. I'd go with Indy's intake if hood clearance is an issue and you want to use a single carb. go for a 4.5" bore by 4.5" stroke. .650-.700 cam. Stage V rockers are best standard config gear (top fuel uses them)
Since you might go with a procharger later on, get a good rotating assembly. Most good cranks are expensive but worth it, Callie, kellog, bryant, etc. Rods: Manley pro series I-beams or Oliver Billet rods, or Childs and Albert.
Re: hemi build up? [Re: FASTFISH420] #104415
08/13/08 09:23 PM
08/13/08 09:23 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Might not be cheap, but here is how I would go about it.
Shortblock.
=New iron World block.
-Callies/Crower crank
-Oliver rods.
-Pistons- several mfgs with excellent Hemi inventory.
Heads;
-Give a call to Jeff at Modern and have him set you up with a set of CNC'ed heads.
- Barton/T&D rocker setup.
Intake
Ported Barton crossram with a set of Dale Cubic prepped SS carbs. There are better induction setups out there, I just like crossrams, especially on a Hemi.
These are some of the items I would choose. Not a budget build, by any means, but not bank breaking either.
MB
Re: hemi build up? [Re: FASTFISH420] #104416
08/13/08 09:25 PM
08/13/08 09:25 PM
65HemiCoronet Offline
I don't think you can say "hemi" and "not break the bank" in the same sentence.........
Yeah, it's got a hemi........a REAL hemi.
Re: hemi build up? [Re: FASTFISH420] #104417
08/13/08 09:31 PM
08/13/08 09:31 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Im wanting to build a 572 HEMI myself..
I have the Callies 4.5 crank..
may go with the new world products aluminum block
definately the stageV heads from Modern Cyl
pump gas a must
and converted Hilborns to electronic injection with stacks that will stick out of my 63 Dodge with the engine slammed back as far as I can get it without altering the firewall
I figure about 30k
Re: hemi build up? [Re: 65HemiCoronet] #104418
08/13/08 09:35 PM
08/13/08 09:35 PM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
You beet me to it!! By the way,How iz inda bank??????
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: hemi build up? [Re: hemi-itis] #104419
08/13/08 09:54 PM
08/13/08 09:54 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
here is the info on my street motor;
572ci Aluminum Hemi
HP Performance Aluminum block 4.5" bore
Stage V Racing heads from Modern
Stage V Dual Quad intake
Bryant Billet Crank 4.5"
Oliver Billet Rods 7.1"
Diamond 11:1 pistons
Calico Coated bearings
Milodon dual swinging pickup
Mopar Tach Drive distr
pair of OOTB Holley 830's
Mopar aluminum water pump and housing
.664" 272 @ .050 street roller cam
Re: hemi build up? [Re: hemi-itis] #104420
08/13/08 10:01 PM
08/13/08 10:01 PM
Central,Ohio
Central,Ohio
572 is a good combo,done this with a wedge and worked great.I like the cross-ram look,but would rather go with a single 4 set-up.hood clearence isn't a problem..I was thinking also on the stage V stuff,or just cnc'd mopar heads,by modern..I like the barton individual rocker set-up,but trying to stay away from high dollar rockers like those.the stage v stuff would probably work fine
I will have to make some phone calls to get prices..
Re: hemi build up? [Re: smokinwoody] #104421
08/13/08 10:04 PM
08/13/08 10:04 PM
pump gas a must
I figure about 30k
You mean like this......?
Re: hemi build up? [Re: 65HemiCoronet] #104422
08/13/08 10:18 PM
08/13/08 10:18 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
pump gas a must
I figure about 30k
that be it but with taller stacks...
Re: hemi build up? [Re: smokinwoody] #104423
08/13/08 10:20 PM
08/13/08 10:20 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
much taller!
Re: hemi build up? [Re: smokinwoody] #104424
08/13/08 10:27 PM
08/13/08 10:27 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
pump gas a must
I figure about 30k
[Edited by Moparts - Keep it clean] did you say 30k, is that close to $30,000?
Man oh man I got to get another job.
When things get slow I have some hemi parts and want to get some ideas of a build up, but after this thread I may need to re-think this whole hemi thing.
Re: hemi build up? [Re: Defbob] #104425
08/13/08 10:27 PM
08/13/08 10:27 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
much taller!
Re: hemi build up? [Re: Dodgeman67] #104426
08/13/08 10:33 PM
08/13/08 10:33 PM
Central,Ohio
Central,Ohio
I agree on the 30k reply.I think you can build one lot cheaper than that.The fuel injection and stacks plus manifold,might be what spikes the price on his build...
I had alittle over 20k in the 572 wedge motor I built acouple years ago,and it was packed full of good parts,jesel,callies,indy,etc..I know it was a wedge,but geeze!
Re: hemi build up? [Re: FASTFISH420] #104427
08/13/08 10:39 PM
08/13/08 10:39 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
you can build a Hemi for under $25K
mine is going to be under $25K with the aluminum block
Re: hemi build up? [Re: Defbob] #104428
08/14/08 09:03 AM
08/14/08 09:03 AM
WI.
Scotts71chall Offline
WI.
Any chance I could get a picture of the stage v intake from the bottom, like in up side down?
Defbob, what body is that going in?
Re: hemi build up? [Re: Scotts71chall] #104429
02/14/09 05:58 PM
02/14/09 05:58 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
My '71 Challenger
Re: hemi build up? [Re: Defbob] #104430
02/14/09 06:45 PM
02/14/09 06:45 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I shopped around and save some money by looking for good deals. I went with a new World Iron block. Aluminum is nice, and light, but expect to be 30-40 hp down from the same Iron block
So here is a run down of what I went with everything new except the pistons.
-4.5 bore World block $2500
-4.5 stroke 4340 crank $700
-I beam pro rods $600
-Weisco pistons $150 slightly used from board member
-DLI rockers stands etc ($1800 from board member
-MP/Edelbrock head $3300 + CNC ported from Modern Cylinder head.. The flow 460cfm or so. also setup for correct springs to match my cam spec ready to go.
I went with a solid flat tappet cam which was a custom deal, and some EDM Howards AMC lifters. Im just waiting from the machine shop to balance, finish bore, fit all clearances etc.
I still need new Oil pump, oil pump drive, timing set, push rods, gaskets rings, and bearings which my machinist will supply upon completion of machine work. Engine will have either a MP cross ram, or Indy setup. Total price should come well under $20K so compared to the last wedge I built, the Hemi is just as cheap, although my wedge as aluminum Indy block, and the price diff between the two payed for the more expensive parts like rocker gear etc.. I have no idea for power, the heads are good enough to make 800+HP IMO. Should be right there..And be streetable as well.
BTW
I have pics of any and all this stuff, flow sheets etc, if you want to see anything let me know
Re: hemi build up? [Re: Bob_Coomer] #104431
02/14/09 08:00 PM
02/14/09 08:00 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
This is what I did on my street build up,
World products block prepped by Barton, Honed to match fit the pistons, Align bored, decked, and lifter bushings installed. About $3900.
1 - Comp roller cam and lifters
2 - K1 4.5 stroke crank from Dram
3 - K1 7.0 chevy journal, width rods, .990 pin from Dram
4 - Diamond 4.5" 11 to 1 comp pistons from Dram
5 - Indy CNC ported Legend heads
6 - Milodon pan modified for single static pickup
7 - HV pump and using the pre-machined oil suction in the front of the block.
8 - Block did not require any additional clearancing for the 4.5 stroke.
A couple of things that I also will comment on. If you use a 7.0" rod, your pistons won't require an oil support rail because the .990 pin won't break into the oil ring land.
I don't know what the Indy head pricing is compared to everyone else but it is worth checking into since there heads have integrated stands and they may offer a package deal with the rockers. If you choose this route, by them from a supporting vender and not direct.
The K1 crank and rods are about the best budget crank and rods out there. I have had eagle and other supporting venders stuff that I won't mention so I have a good idea on comparison.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
