Restoration complete - problem with steel wheels ??? #1044253
07/31/11 10:49 PM
07/31/11 10:49 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
I have completed 99% of the restoration on my 70 Challenger.
Trying to get my Original Dog Dish Hubcaps to stay on the new Steel Rims I bought from Year One. They do not snap in place tight enough to drive without falling off. There is a lip for the hubcaps to snap into like the originals, but it's not tight enough...
Any thoughts?
Re: Restoration complete - problem with steel wheels ??? [Re: Texican] #1044254
07/31/11 11:26 PM
07/31/11 11:26 PM
I would call up Year One and complain to them since thats where you got it from.
Re: Restoration complete - problem with steel wheels ??? [Re: ] #1044255
08/01/11 04:10 PM
08/01/11 04:10 PM
MO
cdp Offline
cdp  Offline
MO
another thought is your wheels. Are they OEM mopar?
Car looks fantastic...though dog dish hub caps were on body color steel wheels with Goodyear tires.
Re: Restoration complete - problem with steel wheels ??? [Re: cdp] #1044256
08/01/11 04:54 PM
08/01/11 04:54 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
The wheels are from Year One (supposedly compatible with 70 E-Body). It could be that the hub caps are just wore out and the lip is not as big as it use to be. I'll take a closer look tonight and see if they appear to be worn on the outer lip where it snaps into place.
I was considering to paint the rims red but thought that it would be too much RED. Leaving the rims Black with dog dish hub caps and the headers are the only non-factory options on this car.
I can always change them back pretty easy.
Thanks, I'll let you know what it was.
Re: Restoration complete - problem with steel wheels ??? [Re: Texican] #1044257
08/01/11 05:58 PM
08/01/11 05:58 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Who is the mfgr. of the wheels? Wheel Vintiques?
1MYTGTX
Re: Restoration complete - problem with steel wheels ??? [Re: Texican] #1044258
08/01/11 09:16 PM
08/01/11 09:16 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Maybe the repro wheels are just a little bit too big in the area that the hub cap snaps onto?
Red steel wheels, Red exterior, Red interior.... Not to much Red
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: Restoration complete - problem with steel wheels ??? [Re: cudaized] #1044259
08/01/11 09:25 PM
08/01/11 09:25 PM
Ola, you must be in the red after seeing and having all that red!
Re: Restoration complete - problem with steel wheels ??? [Re: ] #1044260
08/01/11 09:56 PM
08/01/11 09:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
perhaps your original "dog dishes" are just fatiqued?, they're only aluminum, easy enough to "tighen' up the diameter, with some simple metalworking skill,....I'd had original steelies with original "dog dishes" that wouldn't stay affixed either, "see" were the problem is first with retention of the covers on the wheels, then address that area
Re: Restoration complete - problem with steel wheels ??? [Re: DAYCLONA] #1044261
08/01/11 10:14 PM
08/01/11 10:14 PM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
forget the wheels show us more of that garage.. looks cool
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: Restoration complete - problem with steel wheels ??? [Re: 68 Sat] #1044262
08/01/11 10:18 PM
08/01/11 10:18 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Most '70 "dog dish" hub caps are stainless steel. I've never seen a non-smashed one that was "worn" to the point of not staying on the wheel.
If it's happening on all 4 my guess - wheel issues
Re: Restoration complete - problem with steel wheels ??? [Re: DAYCLONA] #1044263
08/01/11 10:28 PM
08/01/11 10:28 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Who says the aftermarket wheels were actually built to OEM specs? My $ is on non correct parts.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Restoration complete - problem with steel wheels ??? [Re: 68 Sat] #1044264
08/03/11 12:35 AM
08/03/11 12:35 AM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Ask and ye shall receive...
The garage is a little dirty but I do get around to cleaning it every couple of weeks.
It's an old brick 50's gas station with a 3-bay garage with an in-ground lift. Works perfect.
Cheers
Re: Restoration complete - problem with steel wheels ??? [Re: AZ_A12_BEE] #1044265
08/03/11 01:29 AM
08/03/11 01:29 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
For what it's worth, steel for wheels is a specific grade with high fatigue resistance. Cornering wheels flex, and repeated flexing can lead to cracks, if the metallurgy isn't right. Flexing is why lost hubcaps mostly congregate at intersections. A wheel maker who wants this steel must buy it in melt lots of around 50 tons. This quantity of raw material shouldn't be a problem for a company in the wheel business, but you have to wonder if an unknown maker's raw materials purchasing standards are up to snuff.
The same grade of steel is also used to make cooling fan hubs. Same repeated flexing in service. Don't stand beside the fan when an engine is reving...
Re: Restoration complete - problem with steel wheels ??? [Re: ] #1044266
08/03/11 09:57 AM
08/03/11 09:57 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Waste of time.
They'll just blame the caps...
Re: Restoration complete - problem with steel wheels ??? [Re: Commando1] #1044267
08/03/11 10:21 AM
08/03/11 10:21 AM
Waste of time.
Yes, but doesn't Year One have a no hassle return policy?
Re: Restoration complete - problem with steel wheels ??? [Re: ] #1044268
08/03/11 10:44 AM
08/03/11 10:44 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've been wanting to go back to steel wheels, red lines, and small hub caps, like my 69 r/t came with, for years. anyhow, i finally got it done yesterday. i used wheel vintique wheels from summit and put the original hub caps back on. the caps snapped in place like original. i'd call the people you got the wheels from and state your problem.
Re: Restoration complete - problem with steel wheels ??? [Re: lewtot184] #1044269
08/03/11 11:00 AM
08/03/11 11:00 AM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
Hey Acme Garage, Your garage is awesome! That's the kind of Garage I need, an old 50's Garage with everything in it that you need. Even the old stlye furnice and duct work! Are you renting or is it yours? And the Gulf sign is too much! Do ever get get people that stop off and ask you for an oil change such as old people thinking that Garage is still open like it was in the 50's?
Re: Restoration complete - problem with steel wheels ??? [Re: superbeedave] #1044270
08/03/11 12:31 PM
08/03/11 12:31 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
It was a Skelly Gas Station during the 50's-60's and a Marathon station before that. 3-bay garage with a lift in the 1st bay.
I bought the property for $35K...de-greased and painted it and have restored 1-2 cars/trucks a year.
I'm an hour North of Dallas (Denison) if you're ever up this way.
Its not for rent or lease but you're welcome to use it if you're passing through and need a place to wrench.
And (YES) people stop all the time and inquire about random services - sometimes I help and they look at me funny when I say no charge -
Re: Restoration complete - problem with steel wheels ??? [Re: 6bblgt] #1044271
08/03/11 03:08 PM
08/03/11 03:08 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
maybe I shouldn't complain about my pre-bent wheel vintiques steelies; at least the caps seem to fit!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Restoration complete - problem with steel wheels ??? [Re: DPelletier] #1044272
08/03/11 09:33 PM
08/03/11 09:33 PM
Maryland
brianz426 Offline
brianz426  Offline
Maryland
Great looking Challenger and garage. Now to your wheels, unless it's the lighting those wheels do not look at all like factory wheels. From the picture it looks like they have too much offset. I would think we should be able to see more of the lugs and the hub area. They look like they are deeper dish wheel than the factory? I bring this up because back in the '80's my Dad wanted a wider wheels for our '68 GTX so he could put slighty larger radial tires on it. Turns out that the wheels from his '79 Country Squire wagon fit perfectly. After getting a set from the junk yard, cleaning and painting, getting new tires we realized that no Chrysler Corp wheel covers or dog dish caps would stay on these wheels. He ended up putting Ford wheel covers on it, it looked awful in my opinion. A few years later when I got the car the first thing I did was put Mopar wheels on it. It was a shame he threw the originals away. Sorry to be long winded, my bet is on the wrong wheels. Hopefully Year One will cooperate.
