Mirror Mounting Nut Tool #104383
08/13/08 04:21 PM
08/13/08 04:21 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Does anyone know where I can get the tool to install the mirror mounting nuts? I had one and the body shop lost it! Now I can't find another.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Mirror Mounting Nut Tool [Re: Erik] #104384
08/13/08 08:22 PM
08/13/08 08:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I got mine at Napa.
Re: Mirror Mounting Nut Tool [Re: Erik] #104385
08/13/08 08:29 PM
08/13/08 08:29 PM
IMGTX Offline
IMGTX  Offline
Harbor Freight sells them too but I just got a long bolt/screw and a couple nuts.
Thread a nut and washer on the bolt and then through the tube nut. Press into the hole and while holding the bolt still tighten the nut until it's tight.
Works great if you only need to do one or two but if you are doing more than a couple buy the tool.
Re: Mirror Mounting Nut Tool [Re: IMGTX] #104386
08/14/08 08:50 AM
08/14/08 08:50 AM
Spring, Texas
RedFish Offline
super street
RedFish  Offline
super street
Spring, Texas
I tried the nut and bolt trick also but it didn't work. For $20 I just bought the tool from Harbor Freight. Took about 2 min. after that.
Howard
You don't stop playing games when you get old, You get old when you stop playing games.
Re: Mirror Mounting Nut Tool [Re: IMGTX] #104387
08/14/08 08:50 AM
08/14/08 08:50 AM
cataclysm80 Offline
cataclysm80  Offline
Good suggestion, I think I'll try that.
Tav
Re: Mirror Mounting Nut Tool [Re: cataclysm80] #104388
08/14/08 10:06 AM
08/14/08 10:06 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I just looked at the websites for Napa & Harbor Freight and didn't see it on either of them. Does anyone have a part number? I tried searching for Barrel Nuts, Barrel Tool, etc.
Re: Mirror Mounting Nut Tool [Re: Erik] #104389
08/14/08 11:48 AM
08/14/08 11:48 AM
Soldotna,Alaska
RT_6_PakShaker Offline
super street
super street
Soldotna,Alaska
Try RIVNUT search
Re: Mirror Mounting Nut Tool [Re: Erik] #104390
08/14/08 11:52 AM
08/14/08 11:52 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: Mirror Mounting Nut Tool [Re: Snoopy] #104391
08/14/08 12:53 PM
08/14/08 12:53 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks. I wasn't planning on a whole kit, but for $17 I got it.
