Can I get 1 hp per cube from? #1043724
07/31/11 09:19 AM
07/31/11 09:19 AM
Australia
Charger VJ RB Offline OP
Australia
A 440 with stealth heads 10 deg retainers/locks, P3690933 springs, xe274 comp cam, Holley SD intake, source H beam rods, FT Zero deck Ross pistons, Q-850 Carb, stock forged crank, Ati Dampner. New HD stamped rockers with custom moly push rods. Ya all think I will get 440 hp?
RB XE274H Q-850
Re: Can I get 1 hp per cube from? [Re: Charger VJ RB] #1043725
07/31/11 10:01 AM
07/31/11 10:01 AM
IN
ahy Offline
ahy  Offline
IN
I think you will come real close or make it. A little clean up on the heads - pocket port - will help. Getting compression in the low/mid 10's will help... if you can setup for zero deck piston height, you will get ideal .040" quench with a common gasket. The quench will help prevent detonation at the higher CR.
Re: Can I get 1 hp per cube from? [Re: Charger VJ RB] #1043726
07/31/11 10:49 AM
07/31/11 10:49 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Nope, I think you will make MORE than 1 HP/CI. Step up a little on the cam specs and you can be over 500HP pretty easy.
