seat cover wrinkles question #1043677
07/31/11 04:24 AM
07/31/11 04:24 AM
California
DamienH Offline OP
DamienH  Offline OP
California
Hello,
I recently completed recovering the front buckets for my 1969 Super Bee.
I used new foam and the seat covers are from Legendary Interiors. Everything came out better than expected except that the seat bottoms have some wrinkles around the front corners of the seat. Since this is my first time recovering seats I am not sure if this is normal or if there is a way to eliminate these wrinkles. Any help is appreciated.
Thank You
Damien Hoffert
Re: seat cover wrinkles question [Re: DamienH] #1043678
07/31/11 03:47 PM
07/31/11 03:47 PM
California
DamienH Offline OP
DamienH  Offline OP
California
Anybody?
Re: seat cover wrinkles question [Re: DamienH] #1043679
07/31/11 03:59 PM
07/31/11 03:59 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Been a while since I did the front buckets for one of my Challengers, but I do remember using a hair dryer and massaging some areas where there were some small wrinkles. Also leaving the seats out in the sun for a time helps. My seats looked perfect not long after I redid them.
I'm trying to get motivated to do my Challenger convertible's front buckets now, those Challenger buckets are a PITA so it's not a job where I look forward to doing another pair!
Re: seat cover wrinkles question [Re: Mastershake340] #1043680
07/31/11 04:12 PM
07/31/11 04:12 PM
California
DamienH Offline OP
DamienH  Offline OP
California
Thanks for the reply. I used a hair dryer and left the the seats in the sun when I was in the process of recovering them. These wrinkles seem to be from the inside seam of the covers. It looks like as the seam is pulled around the corner of the seat the inside seam bunches up but only at the corners. Is this normal?
Re: seat cover wrinkles question [Re: DamienH] #1043681
07/31/11 04:23 PM
07/31/11 04:23 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
That sounds like it might be a sewing defect to me, but it's hard to say for sure without pictures. I've sewed a lot of seat covers and the corners are tricky to sew as the material tends to bunch there.
Re: seat cover wrinkles question [Re: dustergirl340] #1043682
07/31/11 06:08 PM
07/31/11 06:08 PM
crlush Offline
crlush  Offline
any pics????
