i had to give up and walk away from it as i was getting p.o. lol plus poured some concreat for new shop
so tomarrow hope get it to fire
the 7al is working fine as when i pull purple/green harness apart it has killer spark from coil
havent tried from coil while cranking i took pick up back off
can i plug pick up back in and hold it in hand and run metal infront of it ?will it spark?does it need grounded ?or would i be the ground and zap my self?
just trying to determin if prob is with the pickup or in the cap wich looks fine
