2007 Charger Shifter Problem?
#1043627
07/31/11 12:41 AM
07/31/11 12:41 AM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
Yesterday, I got in my Charger to leave somewhere & the shifter would not come out of park - I was away from home & HAD to get going. I kept messing with it & it would not shift. Finally I realized it was either put the force on it to shift or break, or call a wrecker. So I reefed on it & forced it to move down - it broke free & I figgered I broke it, but it worked. Since this whenever I move the shifter out of park, it reluctantly moves.
Anybody else experience this & do you know what the problem/solution is? NEVER had any shifter issues before this. Thanks.
Re: 2007 Charger Shifter Problem?
[Re: Sunroofcuda]
#1043632
07/31/11 10:53 PM
07/31/11 10:53 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
Its the dreaded "pink thingy" park lock out mechanism problem, Replace it with one of these http://www.custombilletstore.com/product_p/1028.htm and you'll never have the problem again,D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
[Re: bigD]
#1043633
08/01/11 11:40 PM
08/01/11 11:40 PM
Sunroofcuda
Highland, MI.
For the halibut, today I called my local Dodge dealer & explained the incident to them & asked if there was a recall or a TSB on this. The service guy I spoke with (my regular contact person) said this is a real RARE thing. He said there is a recall for a lockout spring, but not the pink part we are talking about. He said the shifter assembly is serviced as an ASSEMBLY, & was not familiar with replacing the pink part. (You've got to be kidding me!) Anyway, I said I'd get back with him on this.................
I'm thinking I should get the billet aluminum part & do this myself.
[Re: Sunroofcuda]
#1043635
08/02/11 03:14 AM
08/02/11 03:14 AM
Posts: 15,926 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Very common issue. It is indeed the pink thingy that the lock solenoid cable hooks onto that breaks. It happened to my '06 SRT8. Popping off the plastic chrome trim piece that is around the shifter exposes the cable so that you you can release it with a screwdriver or even ballpoint pen. That is what I did. Then I got the billet piece. If you do it yourself, mark the shift cable (the black one-not the wire one for lock solenoid) so that you install it back in the exact same place. It took me awhile to find the right place to bolt it back in so that when indicator said "R" I was actually in reverse, etc. Also, look closely at the lock solenoid when you remove it. It has a clip holding it down, and it will break very easy. I know two people that broke theirs because they didn't realize it didn't just pop out and was locked. It was not too bad of a job. I spent more time getting the shift cable back in right position than I did actually replacing part. Chargerforums.com has tons of info and pics on this. Good luck.
Facts are stubborn things.
[Re: abodyjoe]
#1043637
08/02/11 11:05 AM
08/02/11 11:05 AM
Sunroofcuda
Highland, MI.
Well, I FORCED mine out of the park position & it is still working, but there is a hesitation to get it out of park in the shifter (tranny works fine). What did I mess-up by doing this? Maybe I'll see if I can get a shifter out of a wreck & install the billet piece ($25.00). I'll get familiar with the installation & assembly before I mess with the one in my car.
[Re: Sunroofcuda]
#1043638
08/02/11 12:54 PM
08/02/11 12:54 PM
Posts: 6,480 Kingston, IL USA!
gts340swinger
Kingston, IL USA!
We got a recall for our 07 Charger but I haven't brought it in yet. Still trying to find a dealer I trust....
Anyway, I thought it was for that mechanism, not just the spring.
Mr. Norm's "Fanatic" (idiot) 71 Mr. Norm's Demon GSS 77 Mr. Norm's personal B250 GSS van 76 Mr. Norm's KZ900 Motor Sports Special 69 Mr. Norm's M code Dart GTS 69 D100 68 Barracuda 64 Valiant V200 07 Charger Daytona SST 6 speed test mule.
[Re: gts340swinger]
#1043640
08/02/11 05:43 PM
08/02/11 05:43 PM
Posts: 11,081 Berlin, N.J.
abodyjoe
Berlin, N.J.
good luck with that. if your area is anything like this area all the chrysler dealers are hacks that shouldn't even have a job at pep boys.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: abodyjoe]
#1043641
08/04/11 01:33 AM
08/04/11 01:33 AM
Sunroofcuda
Highland, MI.
It IS a RECALL!! Here is the notice - I found it in my pile of "to do" stuff: (car is at the dealer - waiting for parts)
